01-07-2010 08:06 AM - edited 03-15-2019 08:59 PM
We are upgrading Exchange 2000(on new hardware) to Exchange 2003. Can we essentially "move" the message store from 2000 to new 2003 server without having to re-install Unity? Or do we have to re-install Unity?
Solved! Go to Solution.
01-07-2010 08:26 AM
Version???
Message store onbox?? offbox???
I suggest you take a look at this link and the topics it covers.
Reconfiguration and Upgrade Guide for Cisco Unity Release 5.x (With Microsoft Exchange)
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcurugex.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-07-2010 08:26 AM
Version???
java
01-07-2010 09:53 AM
Sounds like it is offbox UM with Unity. If that is the case, you will install the system management tools for Exchange 2003 and Sp2, etc on Unity. Then re-run permissions wizard (download latest from unitytoolsdepot). Then run the message store wizard from add/remove programs to add in the stores from 2003.
Wait for AD/Unity/SQL to sync everything up. Once it is tested with 2003 (move one mailbox and test mwi, etc) then you can plan on moving others when time permits.
01-07-2010 11:13 AM
Hey Daniel,
Long time my friend Hope all is well with you,
it's -26 here this morning (yikes). I heard that it is very
cold in your neck of the woods as well, I guess it's all
relative.
You can't receive answers from two better NetPro's than Tommer
and Java (awesome work guys!) , but I thought you may want to read
another thread just in case;
From Ginger (one of my faves)
https://supportforums.cisco.com/message/1212647#1212647
Take care! Cheers!
Rob
