Can we run mgcp and h323 protocols in a single voice 3845 gateway router
Hi to everyone,
It would be greatful if you guys guide me here pls..
Can we run both mgcp and h323 protocols in a single voice 3845 gateway router ?
thanks
shiv
2 ACCEPTED SOLUTIONS
Re: Can we run mgcp and h323 protocols in a single voice 3845 ga
Hi Siva
I don't believe I've ever read anything that recommends against this.
However I have seen customers with this setup, I'm not sure exactly what your trying to do but from experince the only issue I have ever seen with this is where there is srst configure using:  application mgcpapp
The reason is if you put a h323 dial-peer before the application mgcpapp dial-peer, it will never invoke the MGCP dial-peer as it looks from a top down order.
You may beable to change with this the dial-peer hunt however if you order your H323 dial-peer after the application mgcpapp
you shouldnt' have any issues.
The MGCP autogenerated dial-peer prefix can be changed if so desired, ordinarily MGCP dial-peers are generated as 999????.  The following command allows you to change this prefix, however as already stipulated you need to be wary of the order in which they are created:-
ccm-manager config dialpeer-prefix prefix (select a prefix number other that the default 999)
Allan.
Hope this helps, pls rate helpful posts.
Yes, this is done all of the time. Well, maybe not all of the time but enough to make it a common place configuration.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks for your quick reply.But couldnt get a single document which illustrates such scenario.
Is it a recommended / advisable by Cisco ?
thanks
Hi Siva
Oh;Ok.
Thank you so much guys for your quick update.
Allan.
386
