04-13-2012 09:44 AM - edited 03-16-2019 10:38 AM
I've a query on CUCM and Unity connection 8.6.
Can the audit logs be sent to SNMP?
I checked the following URL which says the logs can be scheduled for download through FTP/SFTP but I have a client who wants to send them to a SNMP server.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_6_1/rtmt/rttlc.html#wp1164225
I would appreciate any insight into it.
thanks,
Kapil
Solved! Go to Solution.
04-13-2012 01:53 PM
No, CUCM cannot deliver any type of log over SNMP. You can only use RTMT collect them, or configure a schedule trace collection to an SFTP server. SNMP is not a protocol designed to transfer large amount of log files, there should be no problem with using SFTP.
The customer should have an SFTP server already for it's CUCM backups.
04-13-2012 10:34 AM
Kapil,
I think Cisco's other products namely CUOM/CUSM already work on same logic. You might want to explore those options.
GP.
Pls rate helpful posts !!
04-13-2012 10:44 AM
Hi GP,
Are you saying there is no way to send Audit logs to SNMP without using CUOM/CUSM?
I know we can send alerts to SNMP without using CUOM/CUSM, but I need to know if Audit logs can also be sent similar way or not?
I am looking for a precise answer on the inbuilt capability before advising my client to look for CUOM/CUSM.
See if you can help.
Kapil
04-13-2012 01:53 PM
