can we setup final destination on the fly for a hunt-group on CME 7.1?
CME 7.1 with CUE 7.0.
The requirement is: 5 agents dynamically join/leave the hunt-group(use Hlog). when all the agents left the hunt-group, one agent can have the option to forward the hunt-pilot call to his cell phone. Each day different agent will setup the agent's personal different cell phone number.
I am wondering if anyone can provide me a hint for the above requirement.
Right now, I have a workaround is to configure the final destination to a spare physical phone first line, and from that phone, setup callforwardall to the cell phone on the fly. But this way will require a physical phone.
JJ
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: can we setup final destination on the fly for a hunt-group o
No, if you press the line button before, you can CfwdAll any line on a phone. Just make sure seized state had the softkey.
Of course you can also CFA from the user page that "owns" the DN.
Configure that DN on a second button of one or more multibutton phones.
Press it before CfwdAll.
Done.
cfwdall setting from phone interface only applies to the first button which is not our case (we configured the first button as the hunt-group member).
Not sure if end-user(not administrator) can setup phone button cfwd setting from end-user webpage of CUE. Will try that.
Any more idea?
JJ
Maybe I can try to configure the 2nd or 3rd button as shared line which is the final destination, and to see if SNR feature can work on the 2nd/3rd extension although CME 7.1 SNR says:
"Each IP phone supports only one SNR directory number. "---it didn't mention if it must be the primary button extension.
You are right!
Thanks for your pointing. Great!
You're welcome, thanks for the nice rating and good luck!
178
