Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Can we use LIC-CM-DL-100= for CM8.6
Dears,
Our customer needs addtional 10 CP-7942G for CM8.6, as I know we can only order the minimum 50 user connection licenses LIC-CUCM-USR-A, so I am wondering if we can use the traditional cm device licenses LIC-CM-DL-100= to replace the user connection licenses. The client is concerning about the budget.
Kirin
1 ACCEPTED SOLUTION
Gold
Hi Kirin
No, LIC-CM-DL-100 will not work on CUCM 8.6, you must either use CUWL or UCL licensing part codes.
However, as far as I know, the minimum of 50 UCL licenses ONLY applies to new installations, and not additional users.You should be able to order 10 UCL users using an ADDON top level part code.
HTH. Barry
Gold
Hi Kirin
HTH. Barry
Hi Barry,
Got it, thanks for your help.
Kirin
1636
