Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Can you auto assign extensions to CP99XX series
I have a few CP9971s and CP9951s that I am trying to register with CME. I can manually add and they come up just fine but, if I just plug them up without adding them I get a 401 Unauthorized.
Here is my show run.
version 15.1
hostname Router
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.1.1
ip dhcp pool Voice
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 192.168.1.1
option 150 ip 192.168.1.1
lease 9
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
no supplementary-service h450.7
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
no supplementary-service sip handle-replaces
sip
  registrar server
voice register global
mode cme
source-address 192.168.1.1 port 5060
max-dn 100
max-pool 50
load 9971 sip9971.9-2-2SR1-9
authenticate register
tftp-path flash:
create profile sync 0001431294058847
voice register dn  1
number 1
shared-line
label 1
voice register dn  2
number 2
shared-line
label 2
voice register dn  3
number 3
shared-line
label 3
voice register dn  4
number 4
shared-line
label 4
voice register dn  5
number 5
shared-line
voice register dn  6
number 6
shared-line
voice register dn  7
number 7
shared-line
voice register dn  8
number 8
shared-line
voice register dn  9
number 9
shared-line
voice register pool  1
voice register pool  2
id mac 24B6.5745.EADC
type 9951
number 1 dn 2
voice register pool  3
id mac 58BF.EA20.9D31
type 9951
number 1 dn 3
voice register pool  4
id mac A418.7528.69D2
type 9951
number 1 dn 4
voice-card 0
license udi pid CISCO2821 sn FTX1340AKNH
username system privilege 15 secret 4 iwLaMS24lhnMr4rFVYJA9wiXll1vHMtldUmHuj/rw5A
redundancy
no ip ftp passive
interface GigabitEthernet0/0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
tftp-server flash:dkern9971.100609R2-9-2-2SR1-9.sebn alias dkern9971.100609R2-9-2-2SR1-9.sebn
tftp-server flash:kern9971.9-2-2SR1-9.sebn alias kern9971.9-2-2SR1-9.sebn
tftp-server flash:rootfs9971.9-2-2SR1-9.sebn alias rootfs9971.9-2-2SR1-9.sebn
tftp-server flash:sboot9971.031610R1-9-2-2SR1-9.sebn alias sboot9971.031610R1-9-2-2SR1-9.sebn
tftp-server flash:sip9971.9-2-2SR1-9.loads alias sip9971.9-2-2SR1-9.loads
tftp-server flash:skern9971.022809R2-9-2-2SR1-9.sebn alias skern9971.022809R2-9-2-2SR1-9.sebn
tftp-server flash:sip9951.9-2-2SR1-9.loads alias sip9951.9-2-2SR1-9.loads
tftp-server flash:/United_States/g4-tones.xml
tftp-server flash:United_States/g4-tones.xml
control-plane
mgcp profile default
telephony-service
max-ephones 50
max-dn 100
ip source-address 192.168.1.1 port 2000
max-redirect 5
auto-register 5-40
cnf-file location flash:
max-conferences 8 gain -6
web admin system name system secret 5 $1$T2T5$BOfsYOYi9gX0PQ7OGB.b1/
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-template  1
softkeys hold  Join Newcall Resume Select
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Redial Endcall Cfwdall Pickup Gpickup Callback
softkeys alerting  Acct Callback Endcall
softkeys connected  Hold Endcall Trnsfer Confrn Acct Park
ephone  1
device-security-mode none
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
scheduler allocate 20000 1000
end
and here is the debug.
*Mar  7 19:41:51.739: //181/5D38EDC58041/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
Via: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bK3ddc47e7
From: <sip:1@192.168.1.1>;tag=8cb64f5697f60003388ac6a4-4588b822
To: <sip:1@192.168.1.1>;tag=8C7BC0-1859
Date: Fri, 07 Mar 2014 19:41:51 GMT
Call-ID: 8cb64f56-97f60002-71d8abf2-52f0a9d7@192.168.1.5
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 103 REGISTER
WWW-Authenticate: Digest realm="",nonce="CBC9B4FA000E0C60",algorithm=MD5,qop="au
th"
Content-Length: 0
*Mar  7 19:41:51.823: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.1.1 SIP/2.0
Via: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bK44db1c3e
Max-Forwards: 70
Date: Fri, 01 Jan 1982 00:01:16 GMT
CSeq: 104 REGISTER
User-Agent: Cisco-CP9971/9.2.1
Contact: <sip:1@192.168.1.5:5060;transport=udp>;+sip.instance="<urn:uuid:0000000
0-0000-0000-0000-8cb64f5697f6>";+u.sip!devicename.ccm.cisco.com="SEP8CB64F5697F6
";+u.sip!model.ccm.cisco.com="493"
Authorization: Digest username="",realm="",uri="sip:192.168.1.1",response="e5c7e
cf2b98fecc4f85beedc34e51f45",nonce="CBC9B4FA000E0C60",cnonce="5e47f35a",qop=auth
,nc=00000003,algorithm=MD5
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-c
isco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallbac
k,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.1.0,X-cisco-xsi-8.0.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:24 Name=SEP8CB64F5697F6 ActiveLoad=sip99
71.9-2-2SR1-9.loads InactiveLoad=sip9971.9-4-1-9.loads Last=phone-reg-rej"
Expires: 3600
*Mar  7 19:41:51.827: //181/5D38EDC58041/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 104 REGISTER
Content-Length: 0
Sent:
CSeq: 104 REGISTER
th"
Content-Length: 0
Everyone's tags (4)
Re:Can you auto assign extensions to CP99XX series
Are these phones in the subnet of the CME or remote. If they are remote you can't use auto registration.
Sent from Cisco Technical Support Android App
Same subnet all local. Just running in a lab environment to test these.
In this case, remove authenticate register command and they will use auto registration. Auto registration won't work with authenticate register since you need to define the digest authentication username/password manually for each pool
Ok, so after having done "no authenticate register" the phone are no longer getting the 401 Unauthorized. Now the phone is just continually downloading the XMLDefault.cnf.xml after not finding its SEPxxxxxxxxx.cnf.xml file.
*Mar  8 16:10:21.255: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:21.255: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:21.255: TFTP: Looking for CTLSEP8CB64F5697F6.tlv
*Mar  8 16:10:21.255: TFTP: Sending error 1 No such file
*Mar  8 16:10:21.347: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:21.347: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:21.347: TFTP: Looking for ITLSEP8CB64F5697F6.tlv
*Mar  8 16:10:21.347: TFTP: Sending error 1 No such file
*Mar  8 16:10:21.443: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:21.443: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:21.443: TFTP: Looking for ITLFile.tlv
*Mar  8 16:10:21.443: TFTP: Sending error 1 No such file
*Mar  8 16:10:21.695: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:21.695: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:21.695: TFTP: Looking for SEP8CB64F5697F6.cnf.xml
*Mar  8 16:10:21.695: TFTP: Sending error 1 No such file
*Mar  8 16:10:22.051: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:22.051: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:22.051: TFTP: Looking for XMLDefault.cnf.xml
*Mar  8 16:10:22.055: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 10, size 3238 for process 12
*Mar  8 16:10:22.055: TFTP: Sending block 1 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:22.055: TFTP: Received ACK for block 1, socket_id 0x49CBD70C
*Mar  8 16:10:22.055: TFTP: Sending block 2 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:22.055: TFTP: Received ACK for block 2, socket_id 0x49CBD70C
*Mar  8 16:10:22.055: TFTP: Sending block 3 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:22.059: TFTP: Received ACK for block 3, socket_id 0x49CBD70C
*Mar  8 16:10:22.059: TFTP: Sending block 4 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:22.063: TFTP: Received ACK for block 4, socket_id 0x49CBD70C
*Mar  8 16:10:22.063: TFTP: Sending block 5 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:22.063: TFTP: Received ACK for block 5, socket_id 0x49CBD70C
*Mar  8 16:10:22.063: TFTP: Sending block 6 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:22.063: TFTP: Received ACK for block 6, socket_id 0x49CBD70C
*Mar  8 16:10:22.063: TFTP: Sending block 7 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:22.063: TFTP: Received ACK for block 7, socket_id 0x49CBD70C
*Mar  8 16:10:22.063: TFTP: Finished flash:/its/vrf1/XMLDefault.cnf.xml, time 00:00:00 for process 12
*Mar  8 16:10:52.835: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:52.835: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:52.835: TFTP: Looking for CTLSEP8CB64F5697F6.tlv
*Mar  8 16:10:52.835: TFTP: Sending error 1 No such file
*Mar  8 16:10:52.927: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:52.927: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:52.927: TFTP: Looking for ITLSEP8CB64F5697F6.tlv
*Mar  8 16:10:52.927: TFTP: Sending error 1 No such file
*Mar  8 16:10:53.019: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:53.019: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:53.019: TFTP: Looking for ITLFile.tlv
*Mar  8 16:10:53.019: TFTP: Sending error 1 No such file
*Mar  8 16:10:53.271: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:53.271: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:53.271: TFTP: Looking for SEP8CB64F5697F6.cnf.xml
*Mar  8 16:10:53.271: TFTP: Sending error 1 No such file
*Mar  8 16:10:53.619: TFTP: Server request for port 49225, socket_id 0x49CBD70C for process 12
*Mar  8 16:10:53.623: TFTP: read request from host 192.168.1.4(49225) via GigabitEthernet0/0
*Mar  8 16:10:53.623: TFTP: Looking for XMLDefault.cnf.xml
*Mar  8 16:10:53.623: TFTP: Opened flash:/its/vrf1/XMLDefault.cnf.xml, fd 10, size 3238 for process 12
*Mar  8 16:10:53.623: TFTP: Sending block 1 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:53.623: TFTP: Received ACK for block 1, socket_id 0x49CBD70C
*Mar  8 16:10:53.623: TFTP: Sending block 2 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:53.627: TFTP: Received ACK for block 2, socket_id 0x49CBD70C
*Mar  8 16:10:53.627: TFTP: Sending block 3 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:53.627: TFTP: Received ACK for block 3, socket_id 0x49CBD70C
*Mar  8 16:10:53.627: TFTP: Sending block 4 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:53.631: TFTP: Received ACK for block 4, socket_id 0x49CBD70C
*Mar  8 16:10:53.631: TFTP: Sending block 5 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:53.631: TFTP: Received ACK for block 5, socket_id 0x49CBD70C
*Mar  8 16:10:53.631: TFTP: Sending block 6 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:53.631: TFTP: Received ACK for block 6, socket_id 0x49CBD70C
*Mar  8 16:10:53.631: TFTP: Sending block 7 (retry 0), socket_id 0x49CBD70C
*Mar  8 16:10:53.631: TFTP: Received ACK for block 7, socket_id 0x49CBD70C
106
