Can you Block Unwanted Phone calls in CCM 4.1
Not sure if possible, but a user receives solicitations often and wants to know if there is a way to block unwanted incoming phone calls. I am wondering if it can be done and if so, is it worth the effort as this week it will be X company, next week it will be Y company, etc etc.. Told user to answer call and tell them to take them off call list.
Gene
1 ACCEPTED SOLUTION
Green
Re: Can you Block Unwanted Phone calls in CCM 4.1
correct, not with MGCP
Green
only if using H.323 GWs
check CCO and forum for more info
Nope, using MGCP, so I guess that means I can't???
Green
162
