Can you do MOH off the flash across layer3?
Hi all,
I have two questions
1) I have experienced configuring MOH off the flash by doing intervlan routing on the router however, I have never tried to do it with the switch doing layer 3.
router(moh)--layer 3 ----Switch -- Phone
has anyone tried this out there yet ?
if it has please elaborate what you did
1 REPLY
Re: Can you do MOH off the flash across layer3?
If you are refering to streaming MoH using multicast from a router with an SRST license then yes there is no problem doing this as long as your layer 3 switch can do multicast routing.
Just enable multicast routing in global config and then enable PIM on the interfaces where your IPT endpoints are located.
If you have 3560/3750 layer 3 switches then be aware that the Base images do not support multicast routing so you would need to upgrade to an image that does this.
145
