Can you fax from Outlook using CME and TSP?
Does anyone know of a way to do this? Shouldnt you be able to use the TSP to attach to your line and have your line use an outgoing POTS line or even PRI channel to send faxes? Receiving i'm not as concerned with right now and i'm fairly certain that i can make that work on CUE 3.1.x but what about outbound without needing a fax server?
Any ideas?
Thanks all!
JG
1 REPLY
Re: Can you fax from Outlook using CME and TSP?
Hi Jason,
I highly doubt it. TAPI does not support T.30, T.37 or T.38 fax protocols.
You should be able to use T.37 to do this.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/cisco_ios_fax_services_over_ip_application_guide/t37.html
Good Luck!
111
