can you hide internal numbers ID on call manager
Hi all
is it possible to hide internal phone numbers when calling another extension on call manager ?
cheers
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Call routing>tranformation
Call routing>tranformation>transformation-pattern>calling party transformation..
Attached is a sample config..
Configure CSSthat has access to the xformation partition on 2222 and uncehck use device pool css
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Ayodeji,let's look athttp:/
Ayodeji,
let's look at
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab09/clb09/dialplan.html#pgfId-1583423
CCalling and Called Party Transformation Patterns
A calling party transformation pattern allows the system to adapt the global form of the calling party's number into the local form required by off-cluster networks connected to the route group devices, such as gateways or trunks.
A called party transformation pattern allows the system to adapt the global form of the called party's number into the local form required by off-cluster networks connected to the route group devices.
So, I believe, that a call should go to the gateway/trunk...not to another IP-phone.
Kirill
VIP Super Bronze
Yes it is. You will use
Yes it is. You will use calling party transformation. You configure the extension you want to hide, set the calling party presentation to restricted, assign this pattern/extension to a partition. Then configure a calling party xfrom CSS, assign this partition to it. Go to the devices you want to hide the extension from, uncheck use calling party device pool css, and select the css you just created..Bingo! Every call from that number to these devices will have their CLI witheld..Job done!
Hi There im stuck on how do
Hi There
im stuck on how do do this, could you tell me which pages I need to go into in order?
say I want to hide caller id from 1111 when going to 2222
cheers
VIP Super Bronze
Hello!It is possible, but you
Hello!
It is possible, but you need to use Translation Pattern, not Transformation.
Call Routing->Translation Pattern
Then you configure 2222, and Calling Party Transformation. But you will need to use different Partition and CSS, if you want to use this pattern to hide only spcific DNs.
Transormation Pattern is used while calling outside CUCM.
Kirill
VIP Super Bronze
Kirill..And who says this
Kirill..
And who says this cant be done with transformation pattern? Infact that is the best approach as compared to using a translation pattern
Ayodeji,
let's look at
Kirill
Kirill,
Kirill,
You are correct, I've uploaded a doc that shows how to exactly accomplish this that will work.
Ryan
1458
