Can you route fax calls coming in to another system
Hi all
We have an issue whereby we have some fax numbers that come in on one of our ISDN's but these devices are on another site.
we have call manager on the main site where the numbers come in, then these fax numbers need to route to another telephone system via a gateway.
We ran a test and we can hear the fax coming in, but it beeps and never completes.
can the call manager route these type of calls to another pbx ? if so do i need to check anything ?
cheers
Carl
Verify that you're running
Verify that you're running either "modem pass-through or relay" on both sides. Don't run both types of modem, this will cause issues.
Yosh
HTH Regards, Yosh
Hall of Fame Super Silver
Standardize on one faxing
Standardize on one faxing protocol, ideally protocol based T.38 across all systems. Fax relay is Cisco proprietary and will not work well with other systems.
Chris
32
