Can you run SRST on Main CCM site as well as remote site?
tomtom001
I know that SRST is usually implemented for remote sites, however I only have 1 CCM Publisher located at our NY site with a 2811 mgcp gateway and another 2811 mgcp gateway at our florida site. I will have SRST at the remote site, but was wondering if I can also set up SRST at the NY site with the 2811. Currently if the CCM box goes down, the NY site is stuck while the remote site is still functioning in SRST mode. Thanks for the help!
Jon Nelson
Level 3
Level 3
Absolutely you can. You just need to make sure that the ISR will support the number of devices at your NY location and that you have the SRST feature license. A 2811 will support up to 36 phones and if you need the SRST feature license work with your Cisco partner, but here is the part number: FL-SRST-36
Thank you,
Jon
Jon Nelson
Level 3
Level 3
Thank you,
Jon
Thanks Jon, answered my question perfectly!
+5 for you!
