Can you use a Application User for a SIP credential?
dstine
We are running CUCM 7.1.3.32900-4 and using our Corporate LDAP for end user authentication. In this senario I cannot add users to the End Users, for use with SIP Phones.  If I create a Application User, I cannot use that for the SIP credentials as it only looks in the End Users for that info?  Any ideas of how to associate a Application user with a SIP phone for digest credentials?
Jaime Valencia
Unfortunately you can't if you look at the instructions for 3rd party SIP phones they state you need to create an End User.
You'll need to create them in AD so they sync with CUCM and then use them.
Configuring Non-Cisco SIP Phones
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b09sip3p.html
Step 3
Configure the end user that will be the Digest User.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
