Bronze
Cannont hear or speak on outbound calls
Running a new environment with CM 4.2(3) and gateway configured as h323.
Inbound calls are working fine both ways and under show voice call stat i see the call is using g729r8
Outbound calls are connecting but no sound. on the phone i can see that it is transmitting RTP not receiving any from gateway. in the gateway i see the call is using g711.
Any reasons why inbound and outbound calls are using different codecs?
I tried to change the codec for inbound calls by placing codec g711ulaw under my voip dial-peer but then I got the same issue with outbound calls could no RTP packets being received from gateway.
dial-peer voice 10 voip
destination-pattern 6...
session ipv4: 1.1.1.1
codec g711ulaw
1 REPLY
Re: Cannont hear or speak on outbound calls
Can you confirm that you have bound h323-gateway to specific ip address under the interface which the CallManager endpoint is configure to?
For example
interface loopback0
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.1.1
Another possibilities is that the answer supervision does not get sent correctly when the called device beyond the telco answers the call.
In this instance, failure to receive the answer supervision will cause the gateway not to cut through the audio path in a forward direction which causes one-way voice.
A workaround involves the need to configure 'voice rtp send-recv on' in global configuration.
In some cases you need to establish a two-way audio path as soon as the RTP channel is opened-before the connect message is received from the telco. Try using the command 'voice rtp send-recv' in global configuration.
Hope this helps.
Allan.
114
