Community Member
cannot bring interface up...
I am having problems with layer 1 coming up. I have an AS5400XM connected to a mux with coax. When I set a loopback on the mux layer 1 goes to ACTIVE. So, that would mean my cable and the T3 card are both in good condition. When I take the remove the loopback on the mux layer 1 goes to DEACTIVATED. What am I missing here?
controller T3 7/0
cablelength 15
t1 1 controller
controller T1 7/0:1
framing ESF
pri-group timeslots 1-24
interface Serial7/0:1:23
no ip address
encapsulation ppp
isdn switch-type primary-ni
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: cannot bring interface up...
You have some clock or setting mismatch, begin comparing show controllers t3, etc.
What mux ? Loopback where exactly ?
Controller cannot be up without loopback or live circuit.
Community Member
It's an Edgelink 100. I put the loopback on the DS3 interface and then I get:
Global ISDN Switchtype = primary-ni
ISDN Serial7/0:1:23 interface
dsl 0, interface ISDN Switchtype = primary-ni
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x807FFFFF
Number of L2 Discards = 0, L2 Session ID = 42
Total Allocated ISDN CCBs = 0
Also, on the mux I put a loopback on the T1 side and the PBX that is connected comes up as well.
Community Member
Yep... it ended up being a framing mismatch. The mux default was m23 and the gateway was c-bit. Thanks.
150
