Cannot Call CUCM extensions from H323 Gateway by connection plar
I have the following setup:
  1. Call Manager 5.1
  2. H323 Gateway with SIP Trunk to Call Manager
I am setting up following scenario:
  1. Connected new analog Telephone Line on H323 FXO port
  2. setup connection plar for CUCM Extension on that FXO port
I am not able to call CUCM extension by connection Plar?
Can you please identify and help to solve my problem.
1 REPLY
Green
Can you try using the DP 800 that yo started to configure.
You need to match the incomining pots calls
dial-peer voice 800 pots
no shut
desc *** INCOME FXO PEER MATCHING ***
incoming called-number .
direct-inward-dial
port 0/1/0
Try and test
Alex
Regards, Alex. Please rate useful posts.
323
