Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cannot call forward to external numbers
I have set an external number to call forward when a user is away from their desk phone.  From an inside extension the forward works but when a call comes in from the PSTN and hits the line and then is rerouted to the external number it fails.  Any ideas of what could be causing this?
Thanks for all of the help.
1 ACCEPTED SOLUTION
>> when the external call comes in,
Original Calling Party Number i = 0x2183, '2566138703'
Redirected party / first called: 2220
Incoming Dial-peer=1, & Outgoing Dial-peer=2200
>> when the call is redirected back to PSTN,
Calling Party Number i = 0x2181, '2566138703'
        Plan:ISDN, Type:National
Called Party Number i = 0x80, '2226561'
        Plan:Unknown, Type:Unknown
Incoming Dial-peer=6750 & Outgoing Dial-peer=9
then the gateway disconneting the redirected call with 80AF
Jan 23 13:20:27.258: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x1D89
     Cause i = 0x80AF - Resource unavailable, unspecified
So as Joseph suggested, please crosscheck those dial peers for any codec mismatch.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
Re: Cannot call forward to external numbers
Look at the debugs from th GW to find out the reason code, and if it even makes it to the GW
java
if this helps, please rate
www.cisco.com/go/pdi
To explain a little more, it works when an internal extension dials the extension in question and when you dial into the Auto Attendant then dial the extension in question.  It does not work when you dial the DID number and it transfers you back out.
WORKING CALL --> DEBUGS RUNNING debug voip dialpeer / debug voip translations
Jan 23 12:51:36.754: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_voiceport_internal: Found profile LBWCC defined on voice-port
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
   Voice port 0x4889BDE8 dsl=0 timeslot=20 does not belong to any trunk group
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_subst_internal: Error: ruleset for calling number not found
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=6591 rule precedence=1
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=6591 rule precedence=2
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=6591 rule precedence=3
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=6591 rule precedence=4
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: Matched with rule 5 in ruleset 1
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution; pattern=6591 matchPattern=.... replacePattern=6750 replaced pattern=6750
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = subscriber
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2566138703, Called Number=6750, Voice-Interface=0x4889BDE8,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=1
   Calling Number=2566138703, Called Number=6750, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
   Result=NO_MATCH(-1) After All Match Rules Attempt
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=6750, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=6750
   Result=Success(0) after DP_MATCH_DEST
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=6750
Jan 23 12:51:36.758: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_voiceport_internal: Found profile LBWCC defined on voice-port
Jan 23 12:51:36.762: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = subscriber
Jan 23 12:51:36.762: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
Jan 23 12:51:36.762: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Jan 23 12:51:36.762: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_subst_internal: Error: ruleset for redirect-called number not found
Jan 23 12:51:36.762: //-1/EDE65965995C/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A0551EC; count=1
Jan 23 12:51:36.762: //-1/EDE65965995C/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A0FD018
Jan 23 12:51:36.766: //-1/EDE65965995C/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A0551EC; count=1
Jan 23 12:51:36.766: //-1/EDE65965995C/DPM/dpMatchPeersCore:
Jan 23 12:51:36.766: //-1/EDE65965995C/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Jan 23 12:51:36.766: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=6750, Called Number=6750, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 23 12:51:36.770: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 23 12:51:36.770: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 23 12:51:36.770: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=6750, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=6750
   Result=SUCCESS(0)
Jan 23 12:51:36.770: //-1/EDE65965995C/DPM/dpMatchPeersCore:
Jan 23 12:51:36.770: //-1/EDE65965995C/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 23 12:51:36.770: //-1/EDE65965995C/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A0551EC; count=2
Jan 23 12:51:36.770: //-1/EDE65965995C/RXRULE/regxrule_dp_translate: No profile found in peer 6750 for outgoing direction
Jan 23 12:51:36.770: //-1/EDE65965995C/RXRULE/regxrule_dp_translate: calling_number=2566138703 calling_octet=0x21
    called_number=6750 called_octet=0xC1
    redirect_number= redirect_type=-1 redirect_plan=-1    redirect_PI=-1 redirect_SI=-1
Jan 23 12:51:36.774: //-1/EDE65965995C/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A0551EC; count=2
Jan 23 12:51:36.774: //-1/EDE65965995C/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A0FE048
Jan 23 12:51:36.774: //-1/EDE65965995C/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A0551EC; count=2
Jan 23 12:51:36.794: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2566138703, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 23 12:51:36.798: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=2566138703
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Jan 23 12:51:36.798: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
Jan 23 12:51:37.030: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 23 12:51:37.030: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Calling Number=, Called Number=8000, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=8000
   Result=NO_MATCH(-1)
Jan 23 12:51:37.046: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 2566138703 N/A
Jan 23 12:51:44.742: //-1/80B5691B0D00/DPM/dpAssociateIncomingPeerCore:
   Calling Number=8037, Called Number=92226561, Voice-Interface=0x0,
Jan 23 12:51:44.746: //-1/80B5691B0D00/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=6750
Jan 23 12:51:44.746: //-1/80B5691B0D00/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A05A04C; count=1
Jan 23 12:51:44.746: //-1/80B5691B0D00/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A10A7BC
Jan 23 12:51:44.746: //-1/80B5691B0D00/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A05A04C; count=1
Jan 23 12:51:44.746: //-1/80B5691B0D00/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=92226561, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=92226561
Jan 23 12:51:44.746: //-1/80B5691B0D00/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:51:44.746: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=92226561, Called Number=92226561, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 23 12:51:44.746: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:51:44.750: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=92226561, Called Number=, Voice-Interface=0x0,
Jan 23 12:51:44.750: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 23 12:51:44.750: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:51:44.750: //-1/80B5691B0D00/DPM/dpMatchPeersCore:
Jan 23 12:51:44.750: //-1/80B5691B0D00/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:51:44.750: //-1/80B5691B0D00/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A05A04C; count=2
Jan 23 12:51:44.750: //-1/80B5691B0D00/RXRULE/regxrule_dp_translate: No profile found in peer 9 for outgoing direction
Jan 23 12:51:44.750: //-1/80B5691B0D00/RXRULE/regxrule_dp_translate: calling_number=8037 calling_octet=0x0
    called_number=92226561 called_octet=0x80
Jan 23 12:51:44.750: //-1/80B5691B0D00/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
Jan 23 12:51:44.750: //-1/80B5691B0D00/RXRULE/regxrule_vp_translate: calling_number=8037 calling_octet=0x0
    redirect_number= redirect_type=4294967295 redirect_plan=4294967295
Jan 23 12:51:44.850: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=8037, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=8037
Jan 23 12:51:44.850: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:51:46.158: %ENVMON-4-FAN_LOW_RPM: Fan 1 service recommended
Jan 23 12:51:46.158: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
Jan 23 12:51:47.298: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 2226561 N/A
Jan 23 12:51:47.298: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 23 12:51:47.298: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:51:48.934: %ISDN-6-DISCONNECT: Interface Serial0/0/0:19  disconnected from 2566138703 , call lasted 11 seconds
Jan 23 12:51:48.954: //-1/EDE65965995C/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Jan 23 12:51:48.962: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jan 23 12:51:48.966: //-1/EDE65965995C/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A0551EC; count=2
Jan 23 12:51:48.966: //-1/EDE65965995C/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A0FE048
Jan 23 12:51:48.970: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=, Called Number=, Voice-Interface=0x0,
Jan 23 12:51:48.986: //-1/80B5691B0D00/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A05A04C; count=2
Jan 23 12:51:48.986: //-1/80B5691B0D00/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A1031CC
Jan 23 12:51:48.990: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jan 23 12:51:48.994: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22  disconnected from 2226561 , call lasted 1 seconds
Jan 23 12:51:49.038: //-1/80B5691B0D00/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Jan 23 12:51:49.042: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=9T, Called Number=, Voice-Interface=0x0,
NONWORKING CALL
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_voiceport_internal: Found profile LBWCC defined on voice-port
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_trunkgroup_internal:
   Voice port 0x4889BDE8 dsl=0 timeslot=4 does not belong to any trunk group
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_subst_internal: Error: ruleset for calling number not found
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=2220 rule precedence=1
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: more digits needed; number=2220 rule precedence=2
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: Matched with rule 3 in ruleset 1
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution; pattern=2220 matchPattern=22 replacePattern=22 replaced pattern=2220
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = subscriber
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
Jan 23 12:59:41.846: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2566138703, Called Number=2220, Voice-Interface=0x4889BDE8,
   Calling Number=2566138703, Called Number=2220, Voice-Interface=0x0,
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=2220, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=2220
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=SUCCESS(0)
     1: Dial-peer Tag=2200
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_profile_from_voiceport_internal: Found profile LBWCC defined on voice-port
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_get_RegXrule: Invalid translation ruleset tag=0
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_subst_internal: Error: ruleset for calling number not found
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: No match; number=2220 rule precedence=1
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_match: more digits needed; number=2220 rule precedence=2
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_match_internal: Matched with rule 3 in ruleset 1
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/sed_subst: Successful substitution; pattern=2220 matchPattern=22 replacePattern=22 replaced pattern=2220
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_type: Match Type = none, Replace Type = none Input Type = subscriber
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_subst_num_plan: Match Plan = none, Replace Plan = none Input Plan = isdn
Jan 23 12:59:41.850: //-1/xxxxxxxxxxxx/RXRULE/regxrule_profile_subst_internal: Error: ruleset for redirect-called number not found
Jan 23 12:59:41.854: //-1/0F098215995F/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A051934; count=1
Jan 23 12:59:41.854: //-1/0F098215995F/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A0FE048
Jan 23 12:59:41.858: //-1/0F098215995F/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A051934; count=1
Jan 23 12:59:41.858: //-1/0F098215995F/DPM/dpMatchPeersCore:
Jan 23 12:59:41.858: //-1/0F098215995F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   Result=SUCCESS(0)
Jan 23 12:59:41.858: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=2220, Called Number=2220, Peer Info Type=DIALPEER_INFO_SPEECH
Jan 23 12:59:41.858: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 23 12:59:41.858: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2220, Called Number=, Voice-Interface=0x0,
   Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=2200
Jan 23 12:59:41.862: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 23 12:59:41.862: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 23 12:59:41.862: //-1/0F098215995F/DPM/dpMatchPeersCore:
Jan 23 12:59:41.862: //-1/0F098215995F/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
Jan 23 12:59:41.862: //-1/0F098215995F/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A051934; count=2
Jan 23 12:59:41.862: //-1/0F098215995F/RXRULE/regxrule_dp_translate: No profile found in peer 2200 for outgoing direction
Jan 23 12:59:41.862: //-1/0F098215995F/RXRULE/regxrule_dp_translate: calling_number=2566138703 calling_octet=0x21
    called_number=2220 called_octet=0xC1
Jan 23 12:59:41.866: //-1/0F098215995F/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A051934; count=2
Jan 23 12:59:41.866: //-1/0F098215995F/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A0FD018
Jan 23 12:59:41.866: //-1/0F098215995F/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A051934; count=2
Jan 23 12:59:41.894: //-1/0022BA371000/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2566138703, Called Number=92226561, Voice-Interface=0x0,
Jan 23 12:59:41.894: //-1/0022BA371000/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A05D434; count=1
Jan 23 12:59:41.894: //-1/0022BA371000/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A103828
Jan 23 12:59:41.894: //-1/0022BA371000/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A05D434; count=1
Jan 23 12:59:41.898: //-1/0022BA371000/DPM/dpMatchPeersCore:
Jan 23 12:59:41.898: //-1/0022BA371000/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:59:41.898: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 23 12:59:41.898: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:59:41.898: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:59:41.902: //-1/0022BA371000/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x4A05D434; count=2
Jan 23 12:59:41.902: //-1/0022BA371000/RXRULE/regxrule_dp_translate: No profile found in peer 9 for outgoing direction
Jan 23 12:59:41.902: //-1/0022BA371000/RXRULE/regxrule_dp_translate: calling_number=2566138703 calling_octet=0x21
Jan 23 12:59:41.902: //-1/0022BA371000/RXRULE/regxrule_vp_translate: No profile found in voice port or trunk group for outgoing direction
Jan 23 12:59:41.902: //-1/0022BA371000/RXRULE/regxrule_vp_translate: calling_number=2566138703 calling_octet=0x21
Jan 23 12:59:42.002: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 23 12:59:42.002: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
     1: Dial-peer Tag=9
Jan 23 12:59:42.022: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Jan 23 12:59:42.022: //-1/xxxxxxxxxxxx/DPM/dpMatchPeers:
   Result=NO_MATCH(-1)
   Result=SUCCESS(0)
Jan 23 12:59:42.042: //-1/0022BA371000/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A05D434; count=2
Jan 23 12:59:42.042: //-1/0022BA371000/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A1052C0
Jan 23 12:59:42.046: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jan 23 12:59:42.082: //-1/0F098215995F/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Jan 23 12:59:42.086: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=22.., Called Number=, Voice-Interface=0x0,
Jan 23 12:59:42.094: //-1/0022BA371000/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x0
Jan 23 12:59:42.098: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jan 23 12:59:42.194: //-1/0F098215995F/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x4A051934; count=2
Jan 23 12:59:42.194: //-1/0F098215995F/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x4A0FD018
Jan 23 12:59:42.194: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Jan 23 12:59:46.158: %ENVMON-4-FAN_LOW_RPM: Fan 1 service recommended
Jan 23 12:59:46.158: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
when the call is redirected back to PSTN, it could have different calling number than the provider expects. or it might be missing the redirect number?
what is the pstn connection? if it is PRI, could you post your running config with debug isdn q931 & debug voice ccapi inout?
collect the debug for 1 non working call (external to internal call cfa to pstn) & 1 working call(internal to internal call cfa to pstn)
WORKING CALL DEBUG WITH DEBUGS SET AS YOU SUGGESTED
Jan 23 13:17:28.414: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x193B
    Bearer Capability i = 0x9090A2
        Standard = CCITT
        Transfer Capability = 3.1kHz Audio
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA98381
        Exclusive, Channel 1
    Facility i = 0x9F8B0100A10F0201A606072A8648CE1500040A0100
    Progress Ind i = 0x8483 - Origination address is non-ISDN
    Called Party Number i = 0xC1, '6591'
        Plan:ISDN, Type:Subscriber(local)
Jan 23 13:17:28.422: //-1/8AC2DCCD9968/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=2566138703
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=6750
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jan 23 13:17:28.422: //-1/8AC2DCCD9968/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x4889BDE8, Call Info(
   Calling Number=2566138703,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=6750(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jan 23 13:17:28.422: //-1/8AC2DCCD9968/CCAPI/ccCheckClipClir:
   In: Calling Number=2566138703(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=2566138703(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Jan 23 13:17:28.422: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:17:28.422: :cc_get_feature_vsa malloc success
Jan 23 13:17:28.422:  cc_get_feature_vsa count is 1
Jan 23 13:17:28.422: :FEATURE_VSA attributes are: feature_name:0,feature_time:1254853224,feature_id:59014
Jan 23 13:17:28.422: //59644/8AC2DCCD9968/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2566138703(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=6750(TON=Subscriber, NPI=ISDN))
Jan 23 13:17:28.426: //59644/8AC2DCCD9968/CCAPI/cc_process_call_setup_ind:
   Event=0x47994810
Jan 23 13:17:28.426: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 6750
Jan 23 13:17:28.426: //59644/8AC2DCCD9968/CCAPI/ccCallSetContext:
   Context=0x4A8E51C0
   >>>>CCAPI handed cid 59644 with tag 1 to app "_ManagedAppProcess_Default"
Jan 23 13:17:28.430: //59644/8AC2DCCD9968/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Jan 23 13:17:28.430: //59644/8AC2DCCD9968/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=6750, Params=0x4B1A0218, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jan 23 13:17:28.430: //59644/8AC2DCCD9968/CCAPI/ccCheckClipClir:
   Destination Pattern=6750, Called Number=6750, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=8AC2DCCD-8367-11E3-9968-001562AF9C78, Outgoing Dial-peer=6750
Jan 23 13:17:28.430: //59644/8AC2DCCD9968/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=6750
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:17:28.434: //59644/8AC2DCCD9968/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x477F3EE4, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=2566138703,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=6750(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=6750, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jan 23 13:17:28.434: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:17:28.434: :cc_get_feature_vsa malloc success
Jan 23 13:17:28.434:  cc_get_feature_vsa count is 2
Jan 23 13:17:28.434: :FEATURE_VSA attributes are: feature_name:0,feature_time:1254853000,feature_id:59015
Jan 23 13:17:28.434: //59645/8AC2DCCD9968/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Jan 23 13:17:28.434: //59645/8AC2DCCD9968/CCAPI/ccCallSetContext:
   Context=0x4B1A01C8
Jan 23 13:17:28.434: //59644/8AC2DCCD9968/CCAPI/ccSaveDialpeerTag:
Jan 23 13:17:28.438: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x993B
Jan 23 13:17:28.450: //59645/8AC2DCCD9968/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Jan 23 13:17:28.450: //59645/8AC2DCCD9968/CCAPI/cc_api_call_proceeding:
   Interface=0x477F3EE4, Progress Indication=NULL(0)
Jan 23 13:17:28.482: //59645/8AC2DCCD9968/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:28.482: //59645/8AC2DCCD9968/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Jan 23 13:17:28.482: //59645/8AC2DCCD9968/CCAPI/cc_api_call_alert:
   Interface=0x477F3EE4, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jan 23 13:17:28.482: //59644/8AC2DCCD9968/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jan 23 13:17:28.486: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x993B
Jan 23 13:17:28.650: //59645/8AC2DCCD9968/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:28.650: //59645/8AC2DCCD9968/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x477F3EE4, Call Id=59645
Jan 23 13:17:28.650: //59645/8AC2DCCD9968/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
Jan 23 13:17:28.654: //59645/8AC2DCCD9968/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Jan 23 13:17:28.654: //59645/8AC2DCCD9968/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
Jan 23 13:17:28.654: //59644/8AC2DCCD9968/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=59644
Jan 23 13:17:28.678: //59645/8AC2DCCD9968/CCAPI/cc_api_call_connected:
   Interface=0x477F3EE4, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Jan 23 13:17:28.678: //59645/8AC2DCCD9968/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:28.678: //59645/8AC2DCCD9968/CCAPI/cc_api_call_notify:
Jan 23 13:17:28.678: //59644/8AC2DCCD9968/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=59644
Jan 23 13:17:28.678: //59644/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46C6A710, callID1=0xE8FC, callID2=0xE8FD, tag=0x0)
   (confID=0x46C6A710, callID1=0xE8FC, gcid=8AC2DCCD-836711E3-99680015-62AF9C78, tag=0x0)
Jan 23 13:17:28.678: //59645/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46C6A710, callID2=0xE8FD, gcid=8AC2DCCD-836711E3-99680015-62AF9C78, tag=0x0)
Jan 23 13:17:28.678: //59644/8AC2DCCD9968/CCAPI/ccConferenceCreate:
   Conference Id=0x46C6A710, Call Id1=59644, Call Id2=59645, Tag=0x0
Jan 23 13:17:28.678: //59644/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x22AF, Source Interface=0x4889BDE8, Source Call Id=59644,
   Destination Call Id=59645, Disposition=0x0, Tag=0xFFFFFFFF
Jan 23 13:17:28.678: //59645/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jan 23 13:17:28.678: cc_api_get_xcode_stream : 4534
Jan 23 13:17:28.678: //59645/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x22AF, Source Interface=0x477F3EE4, Source Call Id=59645,
   Destination Call Id=59644, Disposition=0x0, Tag=0x0
Jan 23 13:17:28.678: //59644/8AC2DCCD9968/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x22AF, Destination Call Id=59645)
Jan 23 13:17:28.678: //59645/8AC2DCCD9968/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x22AF, Destination Call Id=59644)
Jan 23 13:17:28.682: //59644/8AC2DCCD9968/CCAPI/cc_api_caps_ind:
   Destination Interface=0x477F3EE4, Destination Call Id=59645, Source Call Id=59644,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jan 23 13:17:28.682: //59644/8AC2DCCD9968/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x22AF, Call Id1=59644, Call Id2=59645
Jan 23 13:17:28.682: //59645/8AC2DCCD9968/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4889BDE8, Destination Call Id=59644, Source Call Id=59645,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Jan 23 13:17:28.682: //59645/8AC2DCCD9968/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1109)
Jan 23 13:17:28.682: //59644/8AC2DCCD9968/CCAPI/cc_api_caps_ack:
Jan 23 13:17:28.682: //59645/8AC2DCCD9968/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Jan 23 13:17:28.682: //59645/8AC2DCCD9968/CCAPI/cc_api_get_ccm_detected:
Jan 23 13:17:28.682: //59644/8AC2DCCD9968/CCAPI/ccCallNotify:
Jan 23 13:17:28.686: //59644/8AC2DCCD9968/CCAPI/cc_api_voice_mode_event:
   Call Id=59644
   Call Entry(Context=0x4A8E51C0)
Jan 23 13:17:28.686: //59644/8AC2DCCD9968/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
   Call Entry(Connected=TRUE, Responsed=TRUE)
Jan 23 13:17:28.686: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x993B
Jan 23 13:17:28.706: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x193B
Jan 23 13:17:28.706: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 2566138703 N/A
Jan 23 13:17:28.798: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x193B
    Facility i = 0x9F8B0100A118020200A7020100800F414C4142414D412043414C4C202020
Jan 23 13:17:28.798: ISDN Se0/0/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 10, call id 0x197E, call ref 0x993B, event 0x62
Jan 23 13:17:28.798: ISDN Se0/0/0:23 Q931: TX -> STATUS pd = 8  callref = 0x993B
    Cause i = 0x80E262 - Message not compatible with call state or not implemented
    Call State i = 0x0A
Jan 23 13:17:32.026: //59644/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 2 to dstCallId 0xE8FD
Jan 23 13:17:32.026: //59644/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
Jan 23 13:17:32.134: //59644/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Jan 23 13:17:32.134: //59644/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
Jan 23 13:17:32.306: //59644/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Jan 23 13:17:32.306: //59644/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jan 23 13:17:32.418: //59644/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Jan 23 13:17:32.418: //59644/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
Jan 23 13:17:32.606: //59644/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
Jan 23 13:17:32.606: //59644/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jan 23 13:17:32.714: //59644/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Jan 23 13:17:32.714: //59644/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
Jan 23 13:17:32.926: //59644/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 0 to dstCallId 0xE8FD
Jan 23 13:17:32.926: //59644/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
Jan 23 13:17:33.034: //59644/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
Jan 23 13:17:33.034: //59644/xxxxxxxxxxxx/CCAPI/cc_relay_digit_end_for_3way_conference:
Jan 23 13:17:36.398: //59645/8AC2DCCD9968/CCAPI/cc_api_call_media_reset_ind:
   Interface=0x0, Call Id=59645
Jan 23 13:17:36.406: //59645/8AC2DCCD9968/CCAPI/cc_api_call_userinfo:
   Interface=0x477F3EE4, Signal Indication=TONE ON HOLD(14)
Jan 23 13:17:36.406: //59644/8AC2DCCD9968/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=On Hold,
Jan 23 13:17:36.634: //-1/801D7AB81800/CCAPI/cc_api_display_ie_subfields:
   cisco-username=Voicemail
   cisco-ani=8045
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=92226561
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:17:36.634: //-1/801D7AB81800/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x477F3EE4, Call Info(
   Calling Number=8045,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=92226561(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=6750, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=59646
Jan 23 13:17:36.634: //-1/801D7AB81800/CCAPI/ccCheckClipClir:
   In: Calling Number=8045(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=8045(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Jan 23 13:17:36.634: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:17:36.634: :cc_get_feature_vsa malloc success
Jan 23 13:17:36.634:  cc_get_feature_vsa count is 3
Jan 23 13:17:36.634: :FEATURE_VSA attributes are: feature_name:0,feature_time:1254852776,feature_id:59016
Jan 23 13:17:36.634: //59646/801D7AB81800/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=8045(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=92226561(TON=Unknown, NPI=Unknown))
Jan 23 13:17:36.638: //59646/801D7AB81800/CCAPI/cc_process_call_setup_ind:
   Event=0x479901D8
Jan 23 13:17:36.638: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 92226561
Jan 23 13:17:36.638: //59646/801D7AB81800/CCAPI/ccCallSetContext:
   Context=0x4A6FBA08
   >>>>CCAPI handed cid 59646 with tag 6750 to app "_ManagedAppProcess_Default"
Jan 23 13:17:36.638: //59646/801D7AB81800/CCAPI/ccCallProceeding:
Jan 23 13:17:36.638: //59646/801D7AB81800/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x4B46E6E0, Progress Indication=NULL(0)
Jan 23 13:17:36.638: //59646/801D7AB81800/CCAPI/ccCheckClipClir:
   Destination Pattern=9T, Called Number=92226561, Digit Strip=TRUE
   Account Number=Voicemail, Final Destination Flag=TRUE,
   Guid=801D7AB8-7016-112E-1800-D1010A650007, Outgoing Dial-peer=9
Jan 23 13:17:36.642: //59646/801D7AB81800/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=8045
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=92226561
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:17:36.642: //59646/801D7AB81800/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x4889BDE8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=8045,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=92226561(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=9, Call Count On=FALSE,
Jan 23 13:17:36.642: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:17:36.642: :cc_get_feature_vsa malloc success
Jan 23 13:17:36.642:  cc_get_feature_vsa count is 4
Jan 23 13:17:36.642: :FEATURE_VSA attributes are: feature_name:0,feature_time:1254852552,feature_id:59017
Jan 23 13:17:36.642: //59647/801D7AB81800/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jan 23 13:17:36.642: //59647/801D7AB81800/CCAPI/ccCallSetContext:
   Context=0x4B46E690
Jan 23 13:17:36.642: //59646/801D7AB81800/CCAPI/ccSaveDialpeerTag:
Jan 23 13:17:36.646: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x5 is 0x0 0x0, Calling num 8045
Jan 23 13:17:36.646: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x1D88 callID = 0x9D09 switch = primary-dms100 interface = User
Jan 23 13:17:36.646: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x1D88
    Bearer Capability i = 0x8090A2
        Standard = CCITT
        Transfer Capability = Speech
    Channel ID i = 0xA98397
        Exclusive, Channel 23
    Calling Party Number i = 0x0081, '8045'
Jan 23 13:17:36.694: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9D88
Jan 23 13:17:36.698: //59647/801D7AB81800/CCAPI/cc_api_call_proceeding:
   Interface=0x4889BDE8, Progress Indication=NULL(0)
Jan 23 13:17:36.714: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x9D88
    Progress Ind i = 0x8288 - In-band info or appropriate now available
Jan 23 13:17:36.718: //59647/801D7AB81800/CCAPI/cc_api_call_alert:
   Interface=0x4889BDE8, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Jan 23 13:17:36.718: //59646/801D7AB81800/CCAPI/ccCallAlert:
Jan 23 13:17:36.718: //59647/801D7AB81800/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
Jan 23 13:17:36.718: //59646/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46C6A998, callID1=0xE8FE, callID2=0xE8FF, tag=0x0)
   (confID=0x46C6A998, callID1=0xE8FE, gcid=0-0-0-0, tag=0x0)
Jan 23 13:17:36.718: //59647/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46C6A998, callID2=0xE8FF, gcid=0-0-0-0, tag=0x0)
Jan 23 13:17:36.718: //59646/801D7AB81800/CCAPI/ccConferenceCreate:
   Conference Id=0x46C6A998, Call Id1=59646, Call Id2=59647, Tag=0x0
Jan 23 13:17:36.718: //59646/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jan 23 13:17:36.718: cc_api_get_xcode_stream : 4534
Jan 23 13:17:36.718: //59646/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x22B0, Source Interface=0x477F3EE4, Source Call Id=59646,
   Destination Call Id=59647, Disposition=0x0, Tag=0x0
Jan 23 13:17:36.718: //59647/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x22B0, Source Interface=0x4889BDE8, Source Call Id=59647,
   Destination Call Id=59646, Disposition=0x0, Tag=0xFFFFFFFF
Jan 23 13:17:36.718: //59646/801D7AB81800/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x22B0, Destination Call Id=59647)
Jan 23 13:17:36.718: //59647/801D7AB81800/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x22B0, Destination Call Id=59646)
Jan 23 13:17:36.718: //59647/801D7AB81800/CCAPI/cc_api_caps_ind:
   Destination Interface=0x477F3EE4, Destination Call Id=59646, Source Call Id=59647,
Jan 23 13:17:36.722: //59646/801D7AB81800/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
Jan 23 13:17:36.722: //59646/801D7AB81800/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x22B0, Call Id1=59646, Call Id2=59647
Jan 23 13:17:36.722: //59646/801D7AB81800/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=59646
Jan 23 13:17:36.722: //59647/801D7AB81800/CCAPI/cc_api_get_called_ccm_detected:
Jan 23 13:17:36.750: //59646/801D7AB81800/CCAPI/cc_api_caps_ind:
   Destination Interface=0x4889BDE8, Destination Call Id=59647, Source Call Id=59646,
Jan 23 13:17:36.750: //59646/801D7AB81800/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=2417)
Jan 23 13:17:36.750: //59647/801D7AB81800/CCAPI/cc_api_caps_ack:
Jan 23 13:17:36.754: //59647/801D7AB81800/CCAPI/cc_api_voice_mode_event:
   Call Id=59647
   Call Entry(Context=0x4B46E690)
Jan 23 13:17:36.962: //59646/801D7AB81800/CCAPI/cc_api_call_media_reset_ind:
   Interface=0x0, Call Id=59646
Jan 23 13:17:36.970: //59645/8AC2DCCD9968/CCAPI/cc_api_call_userinfo:
   Interface=0x477F3EE4, Signal Indication=TONES OFF(63)
Jan 23 13:17:36.974: //59646/801D7AB81800/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:36.974: //59646/801D7AB81800/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x477F3EE4, Call Id=59646
Jan 23 13:17:36.974: //59645/8AC2DCCD9968/CCAPI/cc_api_call_userinfo:
Jan 23 13:17:36.974: //59645/8AC2DCCD9968/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:36.974: //59645/8AC2DCCD9968/CCAPI/cc_api_call_notify:
Jan 23 13:17:36.974: //59644/8AC2DCCD9968/CCAPI/ccGenerateToneInfo:
Jan 23 13:17:36.974: //59646/801D7AB81800/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Jan 23 13:17:36.974: //59646/801D7AB81800/CCAPI/cc_api_get_ccm_detected:
Jan 23 13:17:36.974: //59647/801D7AB81800/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=59647
Jan 23 13:17:36.974: //59645/8AC2DCCD9968/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Jan 23 13:17:36.974: //59645/8AC2DCCD9968/CCAPI/cc_api_get_ccm_detected:
Jan 23 13:17:36.974: //59644/8AC2DCCD9968/CCAPI/ccCallNotify:
Jan 23 13:17:37.002: //59646/801D7AB81800/CCAPI/cc_api_caps_ind:
Jan 23 13:17:37.006: //59646/801D7AB81800/CCAPI/cc_api_caps_ack:
Jan 23 13:17:37.006: //59647/801D7AB81800/CCAPI/cc_api_caps_ack:
Jan 23 13:17:37.006: //59647/801D7AB81800/CCAPI/cc_api_voice_mode_event:
   Call Id=59647
Jan 23 13:17:37.010: //59645/8AC2DCCD9968/CCAPI/cc_api_caps_ind:
Jan 23 13:17:37.010: //59645/8AC2DCCD9968/CCAPI/cc_api_caps_ack:
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1155)
Jan 23 13:17:37.010: //59644/8AC2DCCD9968/CCAPI/cc_api_caps_ack:
Jan 23 13:17:37.010: //59644/8AC2DCCD9968/CCAPI/cc_api_voice_mode_event:
   Call Id=59644
Jan 23 13:17:37.902: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x9D88
    Progress Ind i = 0x8482 - Destination address is non-ISDN
Jan 23 13:17:37.906: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 2226561 N/A
Jan 23 13:17:37.906: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x1D88
Jan 23 13:17:37.906: //59647/801D7AB81800/CCAPI/cc_api_call_connected:
   Interface=0x4889BDE8, Data Bitmask=0x1, Progress Indication=DESTINATION IS NON ISDN(2),
   Connection Handle=0
Jan 23 13:17:37.906: //59646/801D7AB81800/CCAPI/ccCallConnect:
   Progress Indication=DESTINATION IS NON ISDN(2), Data Bitmask=0x1
Jan 23 13:17:37.910: //59647/801D7AB81800/CCAPI/cc_api_get_called_ccm_detected:
Jan 23 13:17:37.910: //59646/801D7AB81800/CCAPI/ccCallConnect:
Jan 23 13:17:37.910: //59646/801D7AB81800/CCAPI/ccCallNotify:
Jan 23 13:17:37.918: //59645/8AC2DCCD9968/CCAPI/cc_api_call_userinfo:
Jan 23 13:17:37.918: //59645/8AC2DCCD9968/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:37.918: //59645/8AC2DCCD9968/CCAPI/cc_api_call_notify:
Jan 23 13:17:37.918: //59644/8AC2DCCD9968/CCAPI/ccGenerateToneInfo:
Jan 23 13:17:37.922: //59645/8AC2DCCD9968/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Jan 23 13:17:37.922: //59645/8AC2DCCD9968/CCAPI/cc_api_get_ccm_detected:
Jan 23 13:17:37.922: //59644/8AC2DCCD9968/CCAPI/ccCallNotify:
Jan 23 13:17:41.654: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x193B
    Cause i = 0x8090 - Normal call clearing
Jan 23 13:17:41.654: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 2566138703 , call lasted 12 seconds
Jan 23 13:17:41.658: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0x993B
Jan 23 13:17:41.658: //59644/8AC2DCCD9968/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x4889BDE8, Call Id=59644
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Jan 23 13:17:41.658: //59644/8AC2DCCD9968/CCAPI/ccConferenceDestroy:
   Conference Id=0x22AF, Tag=0x0
Jan 23 13:17:41.658: //59644/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=59645, Disposition=0x0, Tag=0x0
Jan 23 13:17:41.658: //59645/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jan 23 13:17:41.658: //59644/8AC2DCCD9968/CCAPI/cc_generic_bridge_done:
Jan 23 13:17:41.662: //59644/8AC2DCCD9968/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jan 23 13:17:41.662: //59644/8AC2DCCD9968/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jan 23 13:17:41.662: //59645/8AC2DCCD9968/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jan 23 13:17:41.662: //59645/8AC2DCCD9968/CCAPI/cc_api_get_transfer_info:
Jan 23 13:17:41.666: //59645/8AC2DCCD9968/CCAPI/cc_api_get_transfer_info:
Jan 23 13:17:41.670: //59645/8AC2DCCD9968/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x477F3EE4, Tag=0x0, Call Id=59645,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Jan 23 13:17:41.670: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 23 13:17:41.670: :cc_free_feature_vsa freeing 4ACB8980
Jan 23 13:17:41.670:  vsacount in free is 3
Jan 23 13:17:41.674: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x193B
Jan 23 13:17:41.686: //59644/8AC2DCCD9968/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4889BDE8, Tag=0x0, Call Id=59644,
Jan 23 13:17:41.686: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 23 13:17:41.686: :cc_free_feature_vsa freeing 4ACB8A60
Jan 23 13:17:41.686:  vsacount in free is 2
Jan 23 13:17:41.698: //59646/801D7AB81800/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x477F3EE4, Call Id=59646
Jan 23 13:17:41.698: //59646/801D7AB81800/CCAPI/ccConferenceDestroy:
   Conference Id=0x22B0, Tag=0x0
Jan 23 13:17:41.698: //59646/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jan 23 13:17:41.698: //59647/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=59646, Disposition=0x0, Tag=0x0
Jan 23 13:17:41.698: //59646/801D7AB81800/CCAPI/cc_generic_bridge_done:
Jan 23 13:17:41.702: //59646/801D7AB81800/CCAPI/ccCallDisconnect:
Jan 23 13:17:41.702: //59646/801D7AB81800/CCAPI/cc_api_get_transfer_info:
Jan 23 13:17:41.702: //59647/801D7AB81800/CCAPI/ccCallDisconnect:
Jan 23 13:17:41.702: //59647/801D7AB81800/CCAPI/cc_api_get_transfer_info:
Jan 23 13:17:41.714: //59646/801D7AB81800/CCAPI/cc_api_get_transfer_info:
Jan 23 13:17:41.714: //59646/801D7AB81800/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x477F3EE4, Tag=0x0, Call Id=59646,
Jan 23 13:17:41.718: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 23 13:17:41.718: :cc_free_feature_vsa freeing 4ACB88A0
Jan 23 13:17:41.718:  vsacount in free is 1
Jan 23 13:17:41.726: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22  disconnected from 2226561 , call lasted 3 seconds
Jan 23 13:17:41.726: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x1D88
Jan 23 13:17:42.146: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x9D88
Jan 23 13:17:42.154: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x1D88
Jan 23 13:17:42.154: //59647/801D7AB81800/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4889BDE8, Tag=0x0, Call Id=59647,
Jan 23 13:17:42.158: //59647/801D7AB81800/CCAPI/cc_api_call_disconnect_done:
Jan 23 13:17:42.158: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 23 13:17:42.158: :cc_free_feature_vsa freeing 4ACB87C0
Jan 23 13:17:42.158:  vsacount in free is 0
Jan 23 13:17:46.158: %ENVMON-4-FAN_LOW_RPM: Fan 1 service recommended
Jan 23 13:17:46.158: %ENVMON-4-FAN_LOW_RPM: Fan 2 service recommended
Jan 23 13:17:48.222: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x193C
        Standard = CCITT
    Channel ID i = 0xA98382
    Facility i = 0x9F8B0100A10F0201AC06072A8648CE1500040A0100
    Calling Party Number i = 0x2183, '8033540126'
    Called Party Number i = 0xC1, '2286'
Jan 23 13:17:48.230: //-1/9691EF4B9969/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=8033540126
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=2286
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:17:48.230: //-1/9691EF4B9969/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=8033540126,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=2286(TON=Subscriber, NPI=ISDN),
Jan 23 13:17:48.230: //-1/9691EF4B9969/CCAPI/ccCheckClipClir:
   In: Calling Number=8033540126(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=8033540126(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
Jan 23 13:17:48.230: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:17:48.230: :cc_get_feature_vsa malloc success
Jan 23 13:17:48.230:  cc_get_feature_vsa count is 1
Jan 23 13:17:48.230: :FEATURE_VSA attributes are: feature_name:0,feature_time:1264770520,feature_id:59018
Jan 23 13:17:48.230: //59648/9691EF4B9969/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=8033540126(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=2286(TON=Subscriber, NPI=ISDN))
Jan 23 13:17:48.234: //59648/9691EF4B9969/CCAPI/cc_process_call_setup_ind:
   Event=0x47994810
Jan 23 13:17:48.234: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 2286
Jan 23 13:17:48.234: //59648/9691EF4B9969/CCAPI/ccCallSetContext:
   Context=0x46BBA804
   >>>>CCAPI handed cid 59648 with tag 1 to app "_ManagedAppProcess_Default"
Jan 23 13:17:48.234: //59648/9691EF4B9969/CCAPI/ccCallProceeding:
Jan 23 13:17:48.238: //59648/9691EF4B9969/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2200, Params=0x4ACE5E38, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jan 23 13:17:48.238: //59648/9691EF4B9969/CCAPI/ccCheckClipClir:
   Destination Pattern=22.., Called Number=2286, Digit Strip=FALSE
   Guid=9691EF4B-8367-11E3-9969-001562AF9C78, Outgoing Dial-peer=2200
Jan 23 13:17:48.238: //59648/9691EF4B9969/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=2286
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:17:48.238: //59648/9691EF4B9969/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=8033540126,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=2286(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2200, Call Count On=FALSE,
Jan 23 13:17:48.238: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:17:48.238: :cc_get_feature_vsa malloc success
Jan 23 13:17:48.238:  cc_get_feature_vsa count is 2
Jan 23 13:17:48.238: :FEATURE_VSA attributes are: feature_name:0,feature_time:1264770296,feature_id:59019
Jan 23 13:17:48.238: //59649/9691EF4B9969/CCAPI/ccIFCallSetupRequestPrivate:
Jan 23 13:17:48.238: //59649/9691EF4B9969/CCAPI/ccCallSetContext:
   Context=0x4ACE5DE8
Jan 23 13:17:48.238: //59648/9691EF4B9969/CCAPI/ccSaveDialpeerTag:
Jan 23 13:17:48.242: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x993C
Jan 23 13:17:48.714: //59649/9691EF4B9969/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:48.714: //59649/9691EF4B9969/CCAPI/cc_api_call_proceeding:
Jan 23 13:17:48.714: ISDN Se0/0/0:23 Q931: RX <- FACILITY pd = 8  callref = 0x193C
    Facility i = 0x9F8B0100A118020200AF020100800F53204341524F4C494E412043414C4C
Jan 23 13:17:48.754: ISDN Se0/0/0:23 **ERROR**: Ux_BadMsg: Invalid Message for call state 9, call id 0x197F, call ref 0x993C, event 0x62
Jan 23 13:17:48.754: ISDN Se0/0/0:23 Q931: TX -> STATUS pd = 8  callref = 0x993C
    Call State i = 0x09
Jan 23 13:17:48.758: //59649/9691EF4B9969/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:48.758: //59649/9691EF4B9969/CCAPI/cc_api_set_delay_xport:
Jan 23 13:17:48.758: //59649/9691EF4B9969/CCAPI/cc_api_call_alert:
Jan 23 13:17:48.762: //59649/9691EF4B9969/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:17:48.762: //59649/9691EF4B9969/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x477F3EE4, Call Id=59649
Jan 23 13:17:48.762: //59648/9691EF4B9969/CCAPI/ccCallAlert:
Jan 23 13:17:48.766: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x993C
Jan 23 13:17:48.774: //59649/9691EF4B9969/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Jan 23 13:17:48.774: //59649/9691EF4B9969/CCAPI/cc_api_get_ccm_detected:
Jan 23 13:17:48.774: //59648/9691EF4B9969/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=59648
NONWORKING CALL WITH SAME DEBUGS
Jan 23 13:20:27.038: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x193E
        Standard = CCITT
    Channel ID i = 0xA9838C
        Exclusive, Channel 12
    Facility i = 0x9F8B0100A10F0201B806072A8648CE1500040A0100
    Called Party Number i = 0xC1, '2220'
Jan 23 13:20:27.046: //-1/F53B5571996B/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=2220
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:20:27.046: //-1/F53B5571996B/CCAPI/cc_api_call_setup_ind_common:
   Called Number=2220(TON=Subscriber, NPI=ISDN),
Jan 23 13:20:27.046: //-1/F53B5571996B/CCAPI/ccCheckClipClir:
Jan 23 13:20:27.046: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:20:27.046: :cc_get_feature_vsa malloc success
Jan 23 13:20:27.046:  cc_get_feature_vsa count is 1
Jan 23 13:20:27.046: :FEATURE_VSA attributes are: feature_name:0,feature_time:1256342208,feature_id:59022
Jan 23 13:20:27.050: //59652/F53B5571996B/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Called Number=2220(TON=Subscriber, NPI=ISDN))
Jan 23 13:20:27.050: //59652/F53B5571996B/CCAPI/cc_process_call_setup_ind:
   Event=0x47995218
Jan 23 13:20:27.050: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 2220
Jan 23 13:20:27.050: //59652/F53B5571996B/CCAPI/ccCallSetContext:
   Context=0x4B600CE0
   >>>>CCAPI handed cid 59652 with tag 1 to app "_ManagedAppProcess_Default"
Jan 23 13:20:27.054: //59652/F53B5571996B/CCAPI/ccCallProceeding:
Jan 23 13:20:27.058: //59652/F53B5571996B/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2200, Params=0x4A802ED0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jan 23 13:20:27.058: //59652/F53B5571996B/CCAPI/ccCheckClipClir:
   Destination Pattern=22.., Called Number=2220, Digit Strip=FALSE
   Guid=F53B5571-8367-11E3-996B-001562AF9C78, Outgoing Dial-peer=2200
Jan 23 13:20:27.058: //59652/F53B5571996B/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=2220
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:20:27.058: //59652/F53B5571996B/CCAPI/ccIFCallSetupRequestPrivate:
   Called Number=2220(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
Jan 23 13:20:27.058: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:20:27.058: :cc_get_feature_vsa malloc success
Jan 23 13:20:27.058:  cc_get_feature_vsa count is 2
Jan 23 13:20:27.058: :FEATURE_VSA attributes are: feature_name:0,feature_time:1256341984,feature_id:59023
Jan 23 13:20:27.058: //59653/F53B5571996B/CCAPI/ccIFCallSetupRequestPrivate:
Jan 23 13:20:27.058: //59653/F53B5571996B/CCAPI/ccCallSetContext:
   Context=0x4A802E80
Jan 23 13:20:27.058: //59652/F53B5571996B/CCAPI/ccSaveDialpeerTag:
Jan 23 13:20:27.066: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x993E
Jan 23 13:20:27.074: //59653/F53B5571996B/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:20:27.074: //59653/F53B5571996B/CCAPI/cc_api_call_proceeding:
Jan 23 13:20:27.090: //-1/00A5661E1900/CCAPI/cc_api_display_ie_subfields:
   cisco-username=2566138703
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=92226561
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:20:27.090: //-1/00A5661E1900/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=2566138703,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=59654
Jan 23 13:20:27.090: //-1/00A5661E1900/CCAPI/ccCheckClipClir:
   In: Calling Number=2566138703(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
   Out: Calling Number=2566138703(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
Jan 23 13:20:27.090: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:20:27.090: :cc_get_feature_vsa malloc success
Jan 23 13:20:27.090:  cc_get_feature_vsa count is 3
Jan 23 13:20:27.090: :FEATURE_VSA attributes are: feature_name:0,feature_time:1256341760,feature_id:59024
Jan 23 13:20:27.090: //59654/00A5661E1900/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=2566138703(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Jan 23 13:20:27.094: //59654/00A5661E1900/CCAPI/cc_process_call_setup_ind:
   Event=0x47995218
Jan 23 13:20:27.094: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Jan 23 13:20:27.094: //59654/00A5661E1900/CCAPI/ccCallSetContext:
   Context=0x4A5D9C04
   >>>>CCAPI handed cid 59654 with tag 6750 to app "_ManagedAppProcess_Default"
Jan 23 13:20:27.094: //59654/00A5661E1900/CCAPI/ccCallProceeding:
Jan 23 13:20:27.098: //59654/00A5661E1900/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=9, Params=0x4A5E5AA4, Progress Indication=NULL(0)
Jan 23 13:20:27.098: //59654/00A5661E1900/CCAPI/ccCheckClipClir:
   Account Number=2566138703, Final Destination Flag=TRUE,
   Guid=00A5661E-1B17-112E-1900-D2010A65FFFE, Outgoing Dial-peer=9
Jan 23 13:20:27.098: //59654/00A5661E1900/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=92226561
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jan 23 13:20:27.098: //59654/00A5661E1900/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=2566138703,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
Jan 23 13:20:27.098: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jan 23 13:20:27.098: :cc_get_feature_vsa malloc success
Jan 23 13:20:27.098:  cc_get_feature_vsa count is 4
Jan 23 13:20:27.098: :FEATURE_VSA attributes are: feature_name:0,feature_time:1256341536,feature_id:59025
Jan 23 13:20:27.098: //59655/00A5661E1900/CCAPI/ccIFCallSetupRequestPrivate:
Jan 23 13:20:27.098: //59655/00A5661E1900/CCAPI/ccCallSetContext:
   Context=0x4A5E5A54
Jan 23 13:20:27.098: //59654/00A5661E1900/CCAPI/ccSaveDialpeerTag:
Jan 23 13:20:27.102: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0x5 is 0x2 0x1, Calling num 2566138703
Jan 23 13:20:27.106: ISDN Se0/0/0:23 Q931: Sending SETUP  callref = 0x1D89 callID = 0x9D0A switch = primary-dms100 interface = User
Jan 23 13:20:27.106: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8  callref = 0x1D89
        Standard = CCITT
Jan 23 13:20:27.170: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x9D89
Jan 23 13:20:27.174: //59655/00A5661E1900/CCAPI/cc_api_call_proceeding:
Jan 23 13:20:27.202: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x9D89
Jan 23 13:20:27.206: //59655/00A5661E1900/CCAPI/cc_api_call_alert:
Jan 23 13:20:27.206: //59654/00A5661E1900/CCAPI/ccCallAlert:
Jan 23 13:20:27.206: //59655/00A5661E1900/CCAPI/cc_api_get_called_ccm_detected:
Jan 23 13:20:27.206: //59654/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46C6A638, callID1=0xE906, callID2=0xE907, tag=0x0)
   (confID=0x46C6A638, callID1=0xE906, gcid=0-0-0-0, tag=0x0)
Jan 23 13:20:27.206: //59655/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46C6A638, callID2=0xE907, gcid=0-0-0-0, tag=0x0)
Jan 23 13:20:27.206: //59654/00A5661E1900/CCAPI/ccConferenceCreate:
   Conference Id=0x46C6A638, Call Id1=59654, Call Id2=59655, Tag=0x0
Jan 23 13:20:27.206: //59654/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jan 23 13:20:27.206: cc_api_get_xcode_stream : 4534
Jan 23 13:20:27.206: //59654/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x22B3, Source Interface=0x477F3EE4, Source Call Id=59654,
   Destination Call Id=59655, Disposition=0x0, Tag=0x0
Jan 23 13:20:27.206: //59655/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x22B3, Source Interface=0x4889BDE8, Source Call Id=59655,
   Destination Call Id=59654, Disposition=0x0, Tag=0xFFFFFFFF
Jan 23 13:20:27.210: //59654/00A5661E1900/CCAPI/cc_generic_bridge_done:
Jan 23 13:20:27.210: //59654/00A5661E1900/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x22B3, Destination Call Id=59655)
Jan 23 13:20:27.210: //59655/00A5661E1900/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x22B3, Destination Call Id=59654)
Jan 23 13:20:27.210: //59655/00A5661E1900/CCAPI/cc_api_caps_ind:
   Destination Interface=0x477F3EE4, Destination Call Id=59654, Source Call Id=59655,
Jan 23 13:20:27.210: //59654/00A5661E1900/CCAPI/cc_api_get_delay_xport:
Jan 23 13:20:27.214: //59654/00A5661E1900/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x22B3, Call Id1=59654, Call Id2=59655
Jan 23 13:20:27.214: //59654/00A5661E1900/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=59654
Jan 23 13:20:27.214: //59655/00A5661E1900/CCAPI/cc_api_get_called_ccm_detected:
Jan 23 13:20:27.218: //59653/F53B5571996B/CCAPI/ccIsInfoRingback:
Jan 23 13:20:27.218: //59653/F53B5571996B/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:20:27.218: //59653/F53B5571996B/CCAPI/cc_api_call_alert:
   Interface=0x477F3EE4, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Jan 23 13:20:27.222: //59652/F53B5571996B/CCAPI/ccCallAlert:
Jan 23 13:20:27.222: //59652/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46C6A6C8, callID1=0xE904, callID2=0xE905, tag=0x0)
   (confID=0x46C6A6C8, callID1=0xE904, gcid=F53B5571-836711E3-996B0015-62AF9C78, tag=0x0)
Jan 23 13:20:27.222: //59653/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x46C6A6C8, callID2=0xE905, gcid=F53B5571-836711E3-996B0015-62AF9C78, tag=0x0)
Jan 23 13:20:27.222: //59652/F53B5571996B/CCAPI/ccConferenceCreate:
   Conference Id=0x46C6A6C8, Call Id1=59652, Call Id2=59653, Tag=0x0
Jan 23 13:20:27.222: //59652/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x22B4, Source Interface=0x4889BDE8, Source Call Id=59652,
   Destination Call Id=59653, Disposition=0x0, Tag=0xFFFFFFFF
Jan 23 13:20:27.222: //59653/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Jan 23 13:20:27.222: cc_api_get_xcode_stream : 4534
Jan 23 13:20:27.222: //59653/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x22B4, Source Interface=0x477F3EE4, Source Call Id=59653,
   Destination Call Id=59652, Disposition=0x0, Tag=0x0
Jan 23 13:20:27.222: //59652/F53B5571996B/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x22B4, Destination Call Id=59653)
Jan 23 13:20:27.222: //59653/F53B5571996B/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x22B4, Destination Call Id=59652)
Jan 23 13:20:27.226: //59652/F53B5571996B/CCAPI/cc_api_caps_ind:
   Destination Interface=0x477F3EE4, Destination Call Id=59653, Source Call Id=59652,
Jan 23 13:20:27.226: //59652/F53B5571996B/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x22B4, Call Id1=59652, Call Id2=59653
Jan 23 13:20:27.226: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x993E
Jan 23 13:20:27.242: //59654/00A5661E1900/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x477F3EE4, Call Id=59654
Jan 23 13:20:27.246: //59654/00A5661E1900/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=47, Retry Count=0)
Jan 23 13:20:27.246: //59654/00A5661E1900/CCAPI/ccConferenceDestroy:
   Conference Id=0x22B3, Tag=0x0
Jan 23 13:20:27.246: //59654/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jan 23 13:20:27.246: //59655/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=59654, Disposition=0x0, Tag=0x0
Jan 23 13:20:27.246: //59654/00A5661E1900/CCAPI/cc_generic_bridge_done:
Jan 23 13:20:27.254: //59655/00A5661E1900/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=47, Call Entry(Responsed=TRUE, Cause Value=47)
Jan 23 13:20:27.254: //59655/00A5661E1900/CCAPI/cc_api_get_transfer_info:
Jan 23 13:20:27.258: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x1D89
    Cause i = 0x80AF - Resource unavailable, unspecified
Jan 23 13:20:27.262: //59654/00A5661E1900/CCAPI/ccCallDisconnect:
   Cause Value=47, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=47)
Jan 23 13:20:27.262: //59654/00A5661E1900/CCAPI/cc_api_get_transfer_info:
Jan 23 13:20:27.266: //59654/00A5661E1900/CCAPI/cc_api_get_transfer_info:
Jan 23 13:20:27.270: //59654/00A5661E1900/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x477F3EE4, Tag=0x0, Call Id=59654,
   Call Entry(Disconnect Cause=47, Voice Class Cause Code=0, Retry Count=0)
Jan 23 13:20:27.270: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 23 13:20:27.270: :cc_free_feature_vsa freeing 4AE240F8
Jan 23 13:20:27.270:  vsacount in free is 3
Jan 23 13:20:27.278: //59653/F53B5571996B/CCAPI/cc_api_set_called_ccm_detected:
Jan 23 13:20:27.278: //59653/F53B5571996B/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x477F3EE4, Call Id=59653
Jan 23 13:20:27.278: //59653/F53B5571996B/CCAPI/cc_api_call_disconnected:
   Cause Value=47, Interface=0x477F3EE4, Call Id=59653
Jan 23 13:20:27.286: //59653/F53B5571996B/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Jan 23 13:20:27.286: //59653/F53B5571996B/CCAPI/cc_api_get_ccm_detected:
Jan 23 13:20:27.286: //59652/F53B5571996B/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=59652
Jan 23 13:20:27.286: //59652/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jan 23 13:20:27.286: //59653/F53B5571996B/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=59653
Jan 23 13:20:27.286: //59652/F53B5571996B/CCAPI/ccConferenceDestroy:
   Conference Id=0x22B4, Tag=0x0
Jan 23 13:20:27.286: //59652/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=59653, Disposition=0x0, Tag=0x0
Jan 23 13:20:27.290: //59653/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
Jan 23 13:20:27.290: //59652/F53B5571996B/CCAPI/cc_generic_bridge_done:
Jan 23 13:20:27.294: //59653/F53B5571996B/CCAPI/ccCallDisconnect:
Jan 23 13:20:27.294: //59653/F53B5571996B/CCAPI/cc_api_get_transfer_info:
Jan 23 13:20:27.298: //59653/F53B5571996B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x477F3EE4, Tag=0x0, Call Id=59653,
Jan 23 13:20:27.298: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 23 13:20:27.298: :cc_free_feature_vsa freeing 4AE241D8
Jan 23 13:20:27.298:  vsacount in free is 2
Jan 23 13:20:27.298: //59652/F53B5571996B/CCAPI/ccCallDisconnect:
Jan 23 13:20:27.302: //59652/F53B5571996B/CCAPI/ccCallDisconnect:
Jan 23 13:20:27.302: //59652/F53B5571996B/CCAPI/cc_api_get_transfer_info:
Jan 23 13:20:27.306: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x993E
Jan 23 13:20:27.322: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x9D89
Jan 23 13:20:27.322: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x1D89
Jan 23 13:20:27.330: //59655/00A5661E1900/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4889BDE8, Tag=0x0, Call Id=59655,
Jan 23 13:20:27.330: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 23 13:20:27.330: :cc_free_feature_vsa freeing 4AE24018
Jan 23 13:20:27.330:  vsacount in free is 1
Jan 23 13:20:27.350: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x193E
Jan 23 13:20:27.354: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x993E
Jan 23 13:20:27.358: //59652/F53B5571996B/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x4889BDE8, Tag=0x0, Call Id=59652,
Jan 23 13:20:27.358: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jan 23 13:20:27.358: :cc_free_feature_vsa freeing 4AE242B8
Jan 23 13:20:27.358:  vsacount in free is 0
Cannot call forward to external numbers
>> when the external call comes in,
Original Calling Party Number i = 0x2183, '2566138703'
Redirected party / first called: 2220
Incoming Dial-peer=1, & Outgoing Dial-peer=2200
Calling Party Number i = 0x2181, '2566138703'
        Plan:ISDN, Type:National
Called Party Number i = 0x80, '2226561'
        Plan:Unknown, Type:Unknown
Incoming Dial-peer=6750 & Outgoing Dial-peer=9
then the gateway disconneting the redirected call with 80AF
So as Joseph suggested, please crosscheck those dial peers for any codec mismatch.
Please rate all the useful posts
//Suresh Please rate all the useful posts.
It was a codec mismatch.  It works great now!  Thanks for all of the suggestions!
Have you asigned the right partition/css on the call forward option for the Directory Number.
.i.e enabling pstn partition/css in call forward option in the DN
Have you assigined any partition which asks for Password(FAC) on the call forwarding option in DN.
since internal forwarding is working,kindly check on the css/partition assigned in call forwarding option
Guru
Are you using geolocations (logical partitioning) or is the CallManager service parameter "Block OffNet To OffNet Transfer" enabled?  Otherwise the above posts are the way to go, the redirecting number may be causing problems with the provider accepting the call.
Re: Cannot call forward to external numbers
Failure reason in the non-working call.
Looks like a codec mismatch.  Outgoing dial-peer is 9, incoming dial-peer is 1.  Check what codecs or voice-class codecs are set on those dial-peers and then if those have a common codec you may need to check the CallManager trace to see what the region mappings and codecs available are on that side.
842
