cannot call out from CUCM
Hello, this should be a simple problem to fix as I am only a newbie.
I have a 2801 router running CME which has a SIP connection to my TSP. I have confirmed it is connecting as I have been making calls out and receiving calls. No problems
I have now just added a CUCM 8.6 box which connects to the 2801 router via a SIP trunk.
I am trying (without success) to call out from a phone registered with CUCM via the 2801 gateway.
The calls are leaving CUCM and arriving at the CME gateway but this is where they fail.
I have included the output of a 'debug ccsip call" below, and also attached my CME gateway router config.
I did a "debug voip dialpeer all" and it said the call is matching my outgoing dial peer 1".
Can anyone offer any suggestions as to what is wrong here ? Thanks for any help.
The CUCM phone I am calling from is extension 2001. CUCM is located at 192.168.2.115. I am trying to rin
May 13 07:58:13.763: //57/DB1A1E000000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x6826C3C0
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 2001
Source IP Address (Sig  ): 192.168.2.1
Destn SIP Req Addr:Port  : 192.168.2.115:5060
Destn SIP Resp Addr:Port : 192.168.2.115:51842
Destination Name         : 192.168.2.115
Router#
May 13 07:58:13.763: //57/DB1A1E000000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 192.168.2.1
Source IP Port    (Media): 17714
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 3
Disconnect Cause (SIP)   : 404
  • IP Telephony
Bronze
These are just hints.  Try to troubleshoot based on the call flow, CUCM-->ROUTER-->TSP, inbound and outbound call legs.  Issue the cmd debug voip ccapi ind 2 and see whether it is hitting the router, and try to issue debug voip dialpeer in out see whether it is going out.  and also see the trunk is registered in cucm.
Hall of Fame Super Silver
In your config I dont see IP-IP GW config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
What version of IOS are you running, you may be hitting toll-fraud prevention mechanism, use "debug voice ccapi inout" to confirm.
Can you mask your caller ID to valid ANI digits as you are sending 4 digits now to see if that helps?
Did you try calling the exact same number from CME?
Can you post "debig voice translation" as your debug shows 9 as part of the called number which would explain the 404 number, perhaps it is not being stripped properly.
Chris
Re: cannot call out from CUCM
Hello, thanks.
I turned on "debug voice translation" and "debug ccsip calls". Additonally "debug voice dialpeer" tells me that outgoing dial peer 1 is being matched.
So, "debug ccsip calls" revelas that the leading 9 is not being stripped nor is any negotiated codec being used.
Both of these things should be happening if the outgoing dial peer 1 is being matched.
Also I notice that no incoming dial peer is being matched. Perhaps that is the problem ?
I am unsure how I should correctly configure my incoming dial peer for the call coming from CUCM. Can someone please advise how I should write that ?. The call will be coming across the SIP trunk from a phone with extension 2001.
Here is my output from 'debug dialpeers;:
May 13 20:30:13.137: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number, Called Number=, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number
   Result=Success(0) after DP_MATCH_DEST
May 13 20:30:13.137: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=9, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
May 13 20:30:13.137: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=SUCCESS(0)
   List of Matched Outgoing Dial-peer(s):
     1: Dial-peer Tag=1
May 13 20:30:13.137: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=2001, Called Number=, Voice-Interface=0x0,
   Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
   Result=NO_MATCH(-1) After All Match Rules Attempt
   dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
May 13 20:30:13.141: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
May 13 20:30:13.141: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
May 13 20:30:13.141: //-1/E8B7BE000000/DPM/dpAssociateIncomingPeerCore:
Router#Calling Number=2001, Called Number=, Voice-Interface=0x0,
May 13 20:30:13.145: //-1/E8B7BE000000/DPM/dpMatchSafModulePlugin:
Here are my 'debug voice translation' and 'debug ccsip calls' outputs:
May 13 20:19:44.175: //-1/71CDF5800000/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x6828FEE4; count=1
May 13 20:19:44.175: //-1/71CDF5800000/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x68367EA8
May 13 20:19:44.179: //-1/71CDF5800000/RXRULE/regxrule_get_profile_from_dialpeer_internal: Error: Invalid input peer_tag=0 direction=incoming
May 13 20:19:44.179: //-1/71CDF5800000/RXRULE/regxrule_stack_push_RegXruleNumInfo_internal: stack=0x6828FEE4; count=1
May 13 20:19:44.191: //-1/71CDF5800000/RXRULE/regxrule_stack_pop_RegXruleNumInfo: stack=0x6828FEE4; count=1
May 13 20:19:44.191: //-1/71CDF5800000/RXRULE/regxrule_stack_pop_callinfo_internal: numinfo=0x68367EA8
May 13 20:19:44.191: //224/71CDF5800000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x67C45D38
Called Number            :
Destn SIP Resp Addr:Port : 192.168.2.115:33532
Router#
May 13 20:19:44.191: //224/71CDF5800000/SIP/Call/sipSPIMediaCallInfo:
Media Stream             : 1
Source IP Port    (Media): 18056
Disconnect Cause (CC)    : 21
Disconnect Cause (SIP)   : 403
Router#
Hi.
Try to add.
dial-peer voice 6 voip
answer-address 2...
voice-class codec 1
dtmf-relay rtp-nte
no vad
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
365
