cannot change ringtones
I have a cucm ver 7.0
7941's are being deployed throughout. htere are over 100 phones. all except 2 people can change their native ringtones.
On the ones I cannot change all i get is chirp 1 and chirp 2.
I cannot get the list of the ringtones.
I have checked that the phone allows settings to be changed. Is there anythign else I should check?
1 REPLY
Re: cannot change ringtones
Have you tried taking those 2 phones that can't see the ringtones and plugging them into the same port that a phone that can see the ring tones is plugged in?
I had this happen to me on a 7911 and once i plugged it into a port where the original phone that was plugged in could see the ring tones all the ring tones came up.
I then plugged it back into its original spot and it was working
224
