Community Member
Cannot clear DND on screen 7931?
Dear All,
Do you know how to clear DND on screen 7931 phone?
how to set time on phone? all my phone wrong time and date...
Best Regards,
sn
Community Member
Hi Join,
Reset the phone by disconnect it from the ethernet cable then give it a few second the connect it.
Senan
Community Member
Dear Senan,
i tried already but it still come up.
Best Regards,
SN
Re: Cannot clear DND on screen 7931?
You should start by mentioning what system you have...
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Dear Jaime,
Could you more detail on this one?
Cold i ask you other question that does Cisco has App ( Softphone) install on Iphone or Samsung?
I mean that PC use Cisco IP Communicator and does has any app install on iphone and samsung?
Best Regards,
SN
What system?? CUCM?? CME???
And yes, theres jabber for iphone and jabber for android, search cisco.com for further information
java
Community Member
Dear Jaime,
I use this Cisco Unity Express - Administration Version 8.0.5 .
Note: i use Cisco C2951-CME-SRST/K9.
I think jabber we need to order license but we did not order license.
best Regards,
SN
279
