Cannot complete Conference-CME 8.6 having PVDM3-64
I am using CME 8.6 that is having PVDM3-64. All phones are local to the CME. I am unable to initiate any kind of conference like local, mobile. Below is the config..Kindly suggest:
voice-card 0
dsp services dspfarm
sccp local vlan 70
sccp ccm 10.111.220.31 identifier 1 priority 1 version 7.0+
sccp
sccp ccm group 1
bind interface vlan70
associate ccm 1 priority 1
associate profile 1 register CFB24FD678KBNMP
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
telephony-service
sdspfarm units 2
sdspfarm tag 1 CFB24FD678KBNMP
conference hardware
max-conferences 6 gain -6
ephone-template  1
softkeys hold  Join Newcall Resume Select
softkeys idle  Cfwdall Dnd Gpickup HLog Join Login Newcall Pickup Redial RmLstC
softkeys alerting  Acct Callback Endcall
softkeys connected  Hold Confrn ConfList HLog Join Park RmLstC Select Trnsfer TrnsfVM Acct
softkeys ringing  Answer Dnd HLog
ephone-dn  20  dual-line
number 112
keep-conference end-call
name Reception
Label 112
description Reception
Conference ad-hoc/meetme (gives me error)
ephone  20
mac-address D4D7.4840.0F88
ephone-template 1
type 7942
button 1:20
Bronze
Hi, verify that dspfarm is registered using *show dspfarm profile* and you need to create AD-HOC ephone-dn to make conference work, like these:
ephone-dn 200 dual-line
number A00
conference ad-hoc
no huntstop
ephone-dn 201 dual-line
number A00
conference ad-hoc
preference 1
no huntstop
ephone-dn 202 dual-line
number A00
conference ad-hoc
preference 2
no huntstop
ephone-dn 203 dual-line
number A00
conference ad-hoc
preference 3
no huntstop
ephone-dn 204 dual-line
number A00
conference ad-hoc
preference 4
huntstop
hth
David
Re: Cannot complete Conference-CME 8.6 having PVDM3-64
Hi David,
I configured the settings suggested by you….attached for your info..still I am facing the issue…any more suggestion plz..
Rgds,
Partha
Hall of Fame Super Silver
It looks like you only created 1 ephone-dn for each conference type, you need at least 4, from the documented I provied:
To configure extension numbers for hardware-based multi-party ad hoc and meet-me ad hoc conferencing, based on the maximum number of conference participants you configure, perform the following steps. Ad hoc conferences require four extensions per conference, regardless of how many extensions are actually used by the conference parties.
HTH,
Chris
I shall try your suggestion tomorrow..thanks..
Hi Chris,
I tried doing this. But same issue while trying to do conference “Cannot complete conference”.
ephone-dn 101 dual-line
number 295
name Conference
no huntstop
ephone-dn 102 dual-line
number 296
name Conference
preference 1
no huntstop
ephone-dn 103 dual-line
number 297
name Conference
preference 2
no huntstop
ephone-dn 104 dual-line
number 298
name Conference
preference 3
no huntstop
Rest config for conference remains same…
Rgds,
Partha
Your conference ephone-dns are missing:
"conference ad-hoc"
HTH,
Chris
Hi Chris,
Sorry for sending you the wrong config….Kindly find the config taken from the device:
number 295
name Conference
no huntstop
number 296
name Conference
preference 1
no huntstop
number 297
name Conference
preference 2
no huntstop
number 298
name Conference
preference 3
no huntstop
Do you have conference ephone-dn defined?
Check out the "SCCP: Configuring Multi-Party Ad Hoc Conferencing and Meet-Me Numbers" section in the admin guide:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1021179
HTH,
Chris
On your ephone-dn 20, define a secondary number (number xxx secondary xxxx). Then you conference should work.
What Chris also said will work.
Regard,
Baqari
1106
