Cannot complete inter office Conf call
Hi all,
I am getting an error when trying to make a conference call to another office. If I go to the PSTN and make a conf call it works.
I looked at the region codec's and they say to use g.729 to the other regions
CCM 4.1.3, h.323
Randall
1 ACCEPTED SOLUTION
Re: Cannot complete inter office Conf call
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
CallManager and IOS Gateway DSP Farm Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
most probably you're using a SW conference bridge that only supports G711.
Add a XCODER or use a HW CFB
javalenc
java
How do I add an xcoder?
Thx
Randall
javalenc
java
Here is another question. The user just said it works on his desk phone but not P Comm. 2.0
RC
it probably has the optimize for low BW configured under the IPC preferences on the computer
that checkbox causes IPC to use G729
javalenc
java
I initially tried that, with no luck.
RC
When the 2nd call answers i press the confrn button. Should there be a join button in the template? Maybe I have the wrong button.
RC
join is used when you establish calls using the hold, new call method. if doing conference press cnf 1 time, dial then press cnf again to connect parties
javalenc
java
OK, just wanted to check.
so why would the desktop work and not the IP Comm.
MRG, MRGL, no access to the SW CFB, IPC and CFB in different regions
javalenc
java
I am looking at the MRGLs. US has 2 groups. China has 3. The top group in the China list is the china resource group and the other 2 are the same as US.
RC
250
