06-16-2008 05:19 AM - edited 03-15-2019 11:18 AM
my office in bangkok is having problem connecting international call to a conference call. all of the codec settings are the same. they have no problems connecting local and long distance calls. it's just for international calls. Please advise. they are on ccm 4.1. (3). thank you.
06-16-2008 05:29 AM
SW or HW CFB?
MGCP? H323?
if SW are you 100% sure they're all made using G711??
have you tried resetting the CFBs?
javalenc
if this helps, please rate
06-16-2008 05:45 AM
yes and yes..would the gateway be different?
06-16-2008 06:20 AM
Sure it is not a barring issue, maybe they have configured so to block International conference calls- local regs ?
06-16-2008 06:44 AM
how can I check this?
06-16-2008 07:11 AM
contact your telco to find out
javalenc
06-16-2008 07:22 AM
ok..do I need to tell them to check the barring? what should it be?
06-17-2008 04:09 AM
I was more thinking it is a local barring issue on the CCM- Trunk to trunk allow for international calls
