cannot conferenece international calls
my office in bangkok is having problem connecting international call to a conference call. all of the codec settings are the same. they have no problems connecting local and long distance calls. it's just for international calls. Please advise. they are on ccm 4.1. (3). thank you.
Re: cannot conferenece international calls
SW or HW CFB?
MGCP? H323?
if SW are you 100% sure they're all made using G711??
have you tried resetting the CFBs?
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
yes and yes..would the gateway be different?
Silver
Sure it is not a barring issue, maybe they have configured so to block International conference calls- local regs ?
how can I check this?
contact your telco to find out
javalenc
java
ok..do I need to tell them to check the barring? what should it be?
Silver
I was more thinking it is a local barring issue on the CCM- Trunk to trunk allow for international calls
132
