Silver
Cannot configure ISDN PRI
2811
>sh ver
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FTX1048A6YC
2 FastEthernet interfaces
1 Serial interface
1 terminal line
1 Channelized (E1 or T1)/PRI port
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
2 Voice E & M interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
1007338K bytes of USB Flash usbflash0 (Read/Write)
62720K bytes of ATA CompactFlash (Read/Write)
>sh diag
WIC Slot 1:
VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
Hardware Revision : 0.0
Top Assy. Part Number : 800-22628-05
Board Revision : B0
Deviation Number : 0
Fab Version : 04
PCB Serial Number : FOC11345EER
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : VWIC2-1MFT-T1/E1
Version Identifier : V01
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
I have the card in the router, it shows in sh ver and in the diag, but I cannot configure the global ISDN settings
RET912R001(config)#?
Configure commands:
<--output cut-->
interface Select an interface to configure
ip Global IP configuration subcommands
ipc Configure IPC system
iphc-profile Configure IPHC profile
ipv6 Global IPv6 configuration commands
irec-agent IREC Agent service
isis Global ISIS configuration subcommands
iua Configure ISDN user Adaptation Layer
ivr ivr utility command
ixi IXI Config command
as you can see here there is not even an option for ISDN.
current IOS version:
Version 12.4(11)T1
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Re: Cannot configure ISDN PRI
Hi, have you configured card-type ? Also, do you have PVDM2 in the router ? Without these, no isdn / voice.
Also, while you're there, you would be better to upgrade to a minimum of 12.4(11)XJ4, because what you have can exhibit many many bugs.
Means you have to configure
network-clock-participate wic 1
and
network-clock-select 1 t1 0/1/0
Silver
does that code support DMVPN and Firewall feature set?
This router will also eventually be running in SRST mode and all phones will be configured back to a CUCM 6.1 box at our HQ location.
card-type? not sure what you mean.
sh diag attached.
In global, "card-type 1 T1". After that the controller will appear and you will be able to configure everything. You have DSP resource for 32 channels. I recommend you upgrade IOS before going in production to reduce chances of problems.
Silver
rated and helped.
I will look into the upgrade, this router is in production currently.
I came across this also:
RET912R001(config)#card type T1 0 1
RET912R001(config)#controller T1 0/1/0
RET912R001(config-controller)# framing esf
RET912R001(config-controller)# linecode b8zs
RET912R001(config-controller)# pri-group timeslots 1-24
%ISDN switch-type must be set first.
RET912R001(config-controller)#isdn switch-type primary-ni
%Please configure network-clock-participate wic 1 first
%Insufficient resources to create pri-group - it has been removed
what does this mean?
and
3212
