Cannot create E1 on the 1861 router
Hello!
I have C1861-UC-4FXO-K9 with HWIC-1T1/E1 module and I am trying to configure outgoing calls to PSTN via E1. The first thing I initialize the module and then configure controller E1:
card type e1 0 2
controller E1 0/2/0
channel-group 15 timeslots 1-31 ( ther is no command pri-timeslots, only channel-group)
After that there is a new interface in the system serial 0/2/0:15 but voice-port 0/2/0:15 is absent and I cant configure dial-peer with this voice-port
may I have missed something?
I found that HWIC is not supported voice over E1. Is it possible to somehow solve this problem if our ISP comes PRI E1? May be over FXO ports?
Green
If the ISP is providing ISDN/PRI you can not use FXO
You really only have 2 options
1) Purchase a VWIC2-1MFT-T1/E1 and connect to the ISP PRI
2) Cancel the ISP PRI and ask for 4 x Analogue PSTN lines and wire to the 4FXO ports
Alex
Regards, Alex. Please rate useful posts.
Thanks for your reply!
But 1861 is not supported VWIC2-1MFT-T1/E1. Am I right?
Green
You are abssolutely correct.
The empty HWIC slot can only be used for DATA - Serial,ADSL E1(DATA)
I tried installing the VWIC2-1MFT-T1/E1 in my 1861.
Althought it does show up in the show diag
It can not be configured.
Tried to find some Cisco URLs for confirmation
but the best I can find
1861 DATA sheet
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps5853/ps8321/product_data_sheet0900aecd806c4dce.html
1861  Q & A
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/ps8321/prod_qas0900aecd806c4def.html
So it looks like you need a different router that can support E1 or use Analogue lines
Alex
297
