Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Cannot Delete Unity Subscriber
I am trying to delete a Subscriber from Unity 5.0(1).  When I do so, I get the error "Delete Failed 0x8004010F".  There is nothing else that I can see that seems to be wrong.  Suggestions?
1 ACCEPTED SOLUTION
Re: Cannot Delete Unity Subscriber
Paul,
Could be various things.  If you're in the position I think you are where you just want to delete the object, try Bulk Subscriber Delete from Unity Tools Depot.
Hailey
Try this:
SA page> subscriber > messages page of the subscriber uncheck the option to use MWI notification
Then try to delete again
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Paul,
Hailey
410
