Cannot dial out
Hi All,
This is my first attempt at configuring a Cisco 2901 router with a 4port FXO card and five 7942 phones.  I've got 4 x United Kingdom BT Analogue phone lines connected to each of the ports on the FXO card and the lines are configured by BT with a single number such that if called it will try each of the lines in turn.  This works fine and I have a hunt group setup to ring all the phones when an incoming call is received.  When calling internally the phones also work perfectly.
However, when I try and make any outgoing call to an external number when I press 9 I get an engaged tone.  I've spent hours researching and can't find anything online which will help to explain what I should be configuring.  I've setup dial-peers but am not sure if I also have to set up translation rules etc?  When connecting a standard PSTN phone to the lines they all work fine so I'm guessing I've missed something in the config but am now a bit stumped.
I've setup a trunk group called OUT to use the port 0/0/2 and 0/0/3 for outgoing calls as a preference.
Can anyone please help? Many thanks in advance!
I've listed the config below;
Current configuration : 10054 bytes
! Last configuration change at 12:15:41 GMT Fri Jan 31 2014 by admin
version 15.2
hostname v2901
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
clock timezone GMT 0 0
clock summer-time GMT recurring
ip cef
ip domain name xxxxxxxxxxx.com
ip name-server 10.0.0.2
no ipv6 cef
trunk group OUT
crypto pki trustpoint TP-self-signed-1914596211
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1914596211
revocation-check none
rsakeypair TP-self-signed-1914596211
crypto pki certificate chain TP-self-signed-1914596211
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31393134 35393632 3131301E 170D3133 31303035 30383137
  32315A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 39313435
  39363231 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D25E 88B02CE4 732DB619 422B7BDE 54076238 964D8D23 E31070F6 CCB5FF4B
  765FFABD 4C832DAD E552E6B5 02506602 4D9CC710 4DDA2142 8ED751B6 5B31DA07
  0D2D94F6 90FC5554 5B55157C 76EC94DD 3FBBA331 23D09289 F03F55BD 71EC2AC4
  E085B768 B17979B0 F998C185 BF7D07C3 B502401E 99C72792 49FD1DC5 64CD1014
  FEB50203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14EDA6DE 755014E0 F4759A2D 5EA41320 02B79A4D D7301D06
  03551D0E 04160414 EDA6DE75 5014E0F4 759A2D5E A4132002 B79A4DD7 300D0609
  2A864886 F70D0101 05050003 8181001C 8603B479 F1B47E3C BA1C6DC1 FA55414F
  9BD4F11B 463CF790 13C9032A 43C1C641 8E0F6B10 8C529D10 9823B234 2BC9C440
  28F262B7 71EDFAAF E750E0A5 4DB70CAD F8FB7990 B0213BE1 24DA32C9 8488E8CF
  6A60EEA6 1B0060AC E10A3FAB CD78982A 07F6BF7E C49C4E95 77326752 D992FAB6
  FB424EDD 9B6870C8 242F261A 6283A0
        quit
voice-card 0
voice register global
voice hunt-group 4 parallel
list 1001,1002,1003,1004,1005
timeout 60000
pilot 1000
license udi pid CISCO2901/K9 sn DCZ174094C2
hw-module pvdm 0/0
username admin privilege 15 secret 4 674JxJtJ0vxUgBtKmhP17SISXbn96KX.JqcB4JF0UX6
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 10.0.0.101 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:gui
tftp-server flash://apps42.9-2-1TH1-13.sbn
tftp-server flash://cnu42.9-2-1TH1-13.sbn
tftp-server flash://cvm42sccp.9-2-1TH1-13.sbn
tftp-server flash://dsp42.9-2-1TH1-13.sbn
tftp-server flash://jar42sccp.9-2-1TH1-13.sbn
tftp-server flash://SCCP42.9-2-1S.loads
tftp-server flash://term42.default.loads
tftp-server flash://term62.default.loads
control-plane
voice-port 0/0/0
cptone GB
timing sup-disconnect 85
connection plar 1000
impedance complex3
caller-id enable
voice-port 0/0/1
cptone GB
impedance complex3
caller-id enable
voice-port 0/0/2
trunk-group OUT
cptone GB
impedance complex3
caller-id enable
voice-port 0/0/3
trunk-group OUT
cptone GB
impedance complex3
caller-id enable
mgcp profile default
dial-peer voice 3 pots
trunkgroup OUT
description *** emergency 999 ***
destination-pattern 999
progress_ind alert enable 8
forward-digits 3
prefix 9
dial-peer voice 4 pots
trunkgroup OUT
description *** emergency 112 ***
destination-pattern 9112
forward-digits 4
dial-peer voice 5 pots
trunkgroup OUT
tone ringback alert-no-PI
description *** Dial Peer for Local Call Access 6 Digit***
preference 1
destination-pattern 9[1-8]......
progress_ind setup enable 3
forward-digits all
dial-peer voice 6 pots
trunkgroup OUT
description *** Dial Peer for Local Call Access ***
preference 1
destination-pattern 9080[0,8]T
forward-digits all
dial-peer voice 7 pots
trunkgroup OUT
description *** Dial Peer for National Access ***
preference 1
destination-pattern 90[1-3].........
forward-digits all
dial-peer voice 8 pots
trunkgroup OUT
preference 1
destination-pattern 90845.......
forward-digits all
dial-peer voice 9 pots
trunkgroup OUT
preference 1
destination-pattern 90844[2-9]......
forward-digits all
dial-peer voice 10 pots
trunkgroup OUT
preference 1
destination-pattern 90870.......
forward-digits all
dial-peer voice 11 pots
trunkgroup OUT
preference 1
destination-pattern 90871[2,9]......
forward-digits all
dial-peer voice 12 pots
trunkgroup OUT
description *** Dial Peer for International Operator ***
preference 1
destination-pattern 9100
forward-digits all
dial-peer voice 13 pots
trunkgroup OUT
description *** Dial Peer for Speaking Clock ***
preference 1
destination-pattern 9123
forward-digits all
dial-peer voice 14 pots
trunkgroup OUT
description *** Dial Peer for Number Withhold ***
preference 1
destination-pattern 9141
forward-digits all
dial-peer voice 15 pots
trunkgroup OUT
description *** Dial Peer for Number release and last number ***
preference 1
destination-pattern 9147[0,1]
forward-digits all
dial-peer voice 16 pots
trunkgroup OUT
description *** Dial Peer for Call Return ***
preference 1
destination-pattern 91571
forward-digits all
dial-peer voice 17 pots
trunkgroup OUT
description *** Dial Peer for Directory Enquiries ***
preference 1
forward-digits all
dial-peer voice 18 pots
trunkgroup OUT
description *** Dial Peer for Mobile Access ***
preference 1
destination-pattern 907.........
forward-digits all
dial-peer voice 19 pots
trunkgroup OUT
description *** Dial Peer for International Access ***
preference 1
destination-pattern 900T
forward-digits all
dial-peer voice 20 pots
trunkgroup OUT
description *** Dial Peer for Premium Numbers ***
preference 1
destination-pattern 90898.......
forward-digits all
dial-peer voice 21 pots
trunkgroup OUT
preference 1
destination-pattern 909.........
forward-digits all
dial-peer voice 22 pots
trunkgroup OUT
description *** Dial Peer for Unrestricted Numbers ***
preference 1
destination-pattern 9T
forward-digits all
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 25
max-dn 50
ip source-address 10.0.0.101 port 2000
service phone webAccess 0
system message PB
cnf-file location flash:
network-locale GB
load 7942 SCCP42.9-2-1S.loads
time-zone 21
date-format dd-mm-yy
max-conferences 8 gain -6
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  11  dual-line
number 1001
name Spencer
ephone-dn  12  dual-line
number 1002
name Paul
ephone-dn  13  dual-line
number 1003
name Val
ephone-dn  14  dual-line
number 1004
name Office
ephone-dn  15  dual-line
number 1005
name Warehouse
ephone  1
mac-address 3C0E.236D.F7A3
type 7942
button  1:11
ephone  2
mac-address 3C0E.236D.F604
type 7942
button  1:12
ephone  3
mac-address 3C0E.236D.FA67
type 7942
button  1:13
ephone  4
mac-address C414.3C96.9439
type 7942
button  1:14
ephone  5
mac-address 3C0E.236D.F820
type 7942
button  1:15
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
scheduler allocate 20000 1000
ntp server 10.0.0.101
end
version 15.2
hostname v2901
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
trunk group OUT
        quit
voice-card 0
timeout 60000
pilot 1000
hw-module pvdm 0/0
redundancy
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
voice-port 0/0/0
cptone GB
impedance complex3
caller-id enable
voice-port 0/0/1
cptone GB
impedance complex3
caller-id enable
voice-port 0/0/2
trunk-group OUT
cptone GB
impedance complex3
caller-id enable
voice-port 0/0/3
trunk-group OUT
cptone GB
impedance complex3
caller-id enable
trunkgroup OUT
forward-digits 3
prefix 9
trunkgroup OUT
forward-digits 4
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
trunkgroup OUT
preference 1
forward-digits all
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
max-ephones 25
max-dn 50
system message PB
network-locale GB
time-zone 21
number 1001
name Spencer
number 1002
name Paul
number 1003
name Val
number 1004
name Office
number 1005
name Warehouse
ephone  1
type 7942
button  1:11
ephone  2
type 7942
button  1:12
ephone  3
type 7942
button  1:13
ephone  4
type 7942
button  1:14
ephone  5
type 7942
button  1:15
line con 0
login local
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
line vty 5 15
access-class 23 in
privilege level 15
login local
end
  • IP Telephony
Cannot dial out
Hello Kevin,
You are sending  9 out to PSTN .
You must strip 9 before it leaves the router.
Cannot dial out
Hi Asad,
Do I have to do that for each dial-peer?
Can you advise on how I do this?
Kevin
Cannot dial out
I have modifies all you dial peers, please try a few and then put them all if the first one works.
Thanks.
trunkgroup OUT
forward-digits 3
trunkgroup OUT
forward-digits 3
trunkgroup OUT
preference 1
trunkgroup OUT
preference 1
prefix 080
trunkgroup OUT
preference 1
prefix 0
trunkgroup OUT
preference 1
prefix 0845
trunkgroup OUT
preference 1
forward-digits 11
trunkgroup OUT
preference 1
forward-digits 11
trunkgroup OUT
preference 1
forward-digits 11
trunkgroup OUT
preference 1
forward-digits 3
trunkgroup OUT
preference 1
forward-digits 3
trunkgroup OUT
preference 1
forward-digits 3
trunkgroup OUT
preference 1
forward-digits 4
trunkgroup OUT
preference 1
forward-digits 4
trunkgroup OUT
preference 1
forward-digits 4
trunkgroup OUT
preference 1
forward-digits 11
trunkgroup OUT
preference 1
prefix 00
trunkgroup OUT
preference 1
forward-digits 11
trunkgroup OUT
preference 1
forward-digits 11
trunkgroup OUT
preference 1
Hall of Fame Super Silver
Cannot dial out
You have quite a few overlaping dial peers including catch all 9T, please post "debug voice dialpeer".
Chris
Re:Cannot dial out
Can u try adding a . after 9
Sent from Cisco Technical Support Android App
Re:Cannot dial out
Try adding the voice ports to trunk group out
306
