Cannot enable Span to PC port on IP Phone
Hi all,
I have enabled the "Span to PC Port" in CUCM8.5.1,
but when I press the IP Phone 7970 > Setting > Device Configuration > Ethernet Configuration
It shows the "Span to PC Port" is "No"
Any one know what is the problem ? and how can I enable the Span to PC Port on hard phone?
IP Phone 7970
Load File SCCP70.9-1-1SR1S
Sam
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Did you reset the phone?
Yosh
HTH Regards, Yosh
Super Bronze
I never use 'apply config'. When I do, I always doubt that it did the right thing, and end up resetting anyway just to make sure.
Most people find a reset pretty unintrusive (it won't interrupt a call for example) and for users it does disrupt a little (e.g. Agent Desktop users) an apply will often do the same anyway. I prefer to know mu changes have definately applied.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Yosh
HTH Regards, Yosh
thanks, it works now after reset the phone, i thought the "Apply Config" work the same way... but actually it's not
Super Bronze
Aaron
1306
