Cannot get into CUE CLI
I am looking to do an upgrade of our version of CUE on a 2821 NME.  The current CUE (3.0.4) is currently working fine, however I want to update the version of CME running on my router.  The problem is I cannot get into the service-module session. When I try it is saying connection refused by host... I have tried to clear the line via the service-module integ-service-engine 1/0 session clear and by clearing the tty line that shows in the service-module integ-service-engine 1/0 status (via clear line tty 66).  I have tried shutting down the module and restarting it with no avail.  I am at a loss as to what to do to get into the cli for the CUE.  Any ideas?
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Cannot get into CUE CLI
Under line 66
no exec
transport input all
Bronze
Do you have a copy of the configuration? Can you web to the CUE?
cheers
Mark
The web gui is working fantastically.
interface Loopback0
ip address 172.16.5.2 255.255.255.252
interface Integrated-Service-Engine1/0
ip unnumbered Loopback0
service-module ip address 172.16.5.1 255.255.255.252
service-module ip default-gateway 172.16.5.2
no keepalive
ip route 172.16.5.1 255.255.255.255 Integrated-Service-Engine1/0
dial-peer voice 1000 voip
translation-profile outgoing PSTN-CallForwarding
destination-pattern 600
session protocol sipv2
session target ipv4:172.16.5.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 1010 voip
description Auto Attendant
destination-pattern 650
codec g711ulaw
I would not have noticed any problems if it was not for the upgrade I am attempting to do.
Bronze
Can't seem to see a problem, what command are you using to access the cli?
Mark
#service-module integrated-Service-Engine 1/0 session
Trying 172.16.5.2, 2066 ...
% Connection refused by remote host
#service-module integrated-Service-Engine 1/0 session clear
[confirm]
[OK]
Bronze
very strange , can't see what the issue is.The fact that you can use the CUE and web to it must mean that routing is fine.i can only assume that it maybe a bug in the IOS.what version are you running.I have checked the unity express for bugs regarding this but there is nothing obvious
IOS version 12.4(11)XW9
CUE version 3.0.4
Under line 66
no exec
transport input all
What authentication are you using for the module?
Note: Problem has been solved and checkmarked as such .
4464
