01-22-2009 11:36 AM - edited 03-15-2019 03:42 PM
I receive the following error "CUE has lost contact with the host router. Please enter the CUCM username and password". I have tried about everything in every post on this issue but to no avail. Can someone assit me? I have posted the config.
01-22-2009 11:59 AM
Hi, first of all try this, you don't need these 2 ip routes:
ip route 172.20.45.5 255.255.255.255 Service-Engine1/0
ip route 172.20.45.6 255.255.255.255 Service-Engine1/0
Only this one:
Hope this help
David
01-22-2009 01:54 PM
I removed this IP route, but same result. I am again asked for the web admin hostname of the router, username, and password. I appreciate the help.
Any more ideas?
01-22-2009 03:16 PM
CM can ping CUE and viceversa ?
Login in cue cli to check.
01-22-2009 07:07 PM
I am able to ping CUE from the router and I can ping CME from the CUE CLI session. What should I try next?
01-23-2009 05:11 AM
Hi, sorry for this question, but if it is a new installation, did you start or skip the wizard cue configuracion.
This message is also seen when the administrator decides to change the Cisco CallManager Express web administrator username and password, and the new name and password is not updated in the CUE system.
David
01-23-2009 05:14 AM
I'm not sure if the customer went through the wizard or not. Is it possible to run through it again? If so, how do I initiate it?
01-23-2009 05:23 AM
Hi, only as a last option you can reinstall the CUE (a factory reset) and start a new configuration again.
First login into the CUE, then use the command CUE-Prompt#offline
CUE-Prompt(offline)>restore factory
and reset.
Take care, all your configuration (voicemail and users) will be deleted.
Best regards
David
