01-12-2012 01:39 AM - edited 03-16-2019 08:58 AM
Hello Friends
I Made new Implementation of IPT with CUCM 8.0 (Pub and 1 Sub) and H323 Gateway. Calls are working fine, But When I make Conference call Internally It fails. Suppose from Phone A I called Phone B, Phone B Answer Call. From Phone A I press Conference Button and Dial Phone C, phone C Answer the call, Now from Phone A I press Conference Button Again to have Conference it fails either all call dorp or it revert back to resume Call to Phone B.
Please advice
Abbas
01-12-2012 01:45 AM
Hello Abbas,
I faced a similar kind of issue with my CUCM 8.5. Call Manager service restart fixed the issue.
Karthik
01-12-2012 05:08 AM
Abbas,
What are you using as a conference bridge? Are you using HW bridge or software (CUCM server)? If HW please post config.
Is your conference bridge registered?
Is it assigned to proper MRG
Is the MRGL with this MRG assigned to proper Device Pool?
What regions are used for the call?
Chris
01-14-2012 07:13 AM
Hello Chris
I have Software Conference Bridge and also Hardware Conference bridge configured and registered in CUCM. config is below, Conference Bridge is assigned to proper MRG and MRG is assign to Proper MRGL which is assigned to proper Device pool. we have tested conference in one region and codec is g711, this is new IPT installation.
oice-port 0/0/0:15
sccp local BVI1
sccp ccm 10.188.248.6 identifier 1 priority 1 version 7.0
sccp ccm 10.188.248.5 identifier 2 priority 2 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 1 register WTA-HQ-VG1-CFB1
associate profile 2 register WTA-HQ-VG1-MTP1
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 5
associate application SCCP
dspfarm profile 1 conference
codec g711alaw
codec g711ulaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 3
Thanks and regards
Abbas
01-14-2012 07:30 AM
If you are certian your CUCM configuration is proper, my only suggestion would be to look at CM SDI trace logs for reasons of the drop.
Chris
