Community Member
Cannot make International to a specific country
I have some strange issue with the international dialing. We can call any numbers except call to Venezuela.
I found out what the issue is but I cannot figure it out on where to fix it.
The first call we are sending 011+numbers and the call type is unknown.
The Second call, we are sending 011+numbers and the call type is international (FAILED)
I just talked with the phone company and they are saying that if we cannot send 011 and calltype=international. It has one of them, or either one.
But I don't know why it is only for calls to Venezuela 011+58+numbers. I can make calls to other countries.
At this point, I am not sure where to go to fix the issue, I don't think we make any pattern in outgoing calls. I also check the CUCM and it looks good for the international dialing plan.
Please help, Thanks
FIRST CALL - PASSED
*Feb 26 20:09:35.899: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x3F92
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98395
Exclusive, Channel 21
Calling Party Number i = 0x2181, 'XXXXXX2580'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '011613XXXX4916'
Plan:Unknown, Type:Unknown
*Feb 26 20:09:35.975: ISDN Se0/0/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0xBF92
*Feb 26 20:09:39.015: ISDN Se0/0/0:23 Q931: RX <- ALERTING pd = 8 callref = 0xBF92
Progress Ind i = 0x8088 - In-band info or appropriate now available
*Feb 26 20:09:39.839: ISDN Se0/0/0:23 Q931: RX <- CONNECT pd = 8 callref = 0xBF92
*Feb 26 20:09:39.839: %ISDN-6-CONNECT: Interface Serial0/0/0:20 is now connected to 01161XXXXX916 N/A
*Feb 26 20:09:39.843: ISDN Se0/0/0:23 Q931: TX -> CONNECT_ACK pd = 8 callref = 0x3F92
*Feb 26 20:09:45.031: %ISDN-6-DISCONNECT: Interface Serial0/0/0:20 disconnected from 01161396694916 , call lasted 5 seconds
SECOND CALL - FAILED
*Feb 26 20:08:06.247: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x3F91
Standard = CCITT
Channel ID i = 0xA98396
Exclusive, Channel 22
Calling Party Number i = 0x2181, ' XXXXXX2580'
Called Party Number i = 0x91, '01158212XXXX663'
Plan:ISDN, Type:International
*Feb 26 20:08:06.315: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0xBF91
Cause i = 0x809C - Invalid number format (incomplete number)
Hall of Fame Super Gold
Re: Cannot make International to a specific country
That is correct. Now, there a couple of quirks that you have to consider.
First, sometime due to international routing, strange things happen with a country only or even a subset of it.
Second, depending the switch type confoigured, there is some (wrong) logic in cisco that can force type international behind your back.
So, try the suggestion above, configure for 011... and unknown, or 54.... and international.
Community Member
How can the gateway determine this call type:
Is that from our dialpan in CUCM? or something else.
From your question, I infer you have are using H.323 and isdn switch-type primary-5ess, correct?
I need this confirmed to guide you to the correct configuration.
Community Member
Thank you again for your help,
H.323 - YES
and isdn switch-type primary-5ess - I am not sure
Also we are using CUCM 6.1 if that's matter
Try this quick fix under PRI interface:
isdn map address . plan unknown type unknown
Then check if gets the desired effect, force all calls to unknown numbering plan.
Community Member
So we are adding this script to the PRI interface and it works
But it changed all plan and type to unknown. including the Calling Party Number
is this going to be a problem?
Not necessarily. Check with a cellphone if you are receiving a correct CLID.
Please remember to rate useful posts with the scrollbox below.
Community Member
So i got this from another forum, adding this:
isdn map address 011* plan unknown type unknown
I have not tried it but it seems this will not change all of the call type, only 011*.
Any input if i should do
or
Basically, it's ok to make all outgoing calls unknown type.
If you notice that changing the calling number creates any problem, come back here for an alternative configuration.
Community Member
Hi Friend,
I am facing similar issue...Actually i get the below error when i dial to a particular number (within UAE only).
"incompatible estination".
Plz find attached the logs & sh run & suggest....
We can call to all numbers except the below:
But from Avaya or cell phone we can make calls to that very number...We have CCM 6.1 & Cisco 2821 Voice Gateway..
948
