04-16-2008 06:42 AM - edited 03-15-2019 10:06 AM
Dear All,
The CM cluster was upgraded from 3.3(3) to 3.3(5) via maintenance upgrade. And we suspect the subscriber server is out of order and wants to re-install the subscriber server once.
But we do not have the CM3.3(5)installation disk. We only have 3.3(3) disk.
How can we solve this issue?
Any input will be much appreciated!!
Michael.
Solved! Go to Solution.
04-16-2008 06:45 AM
Hi Michael,
You can take the Subscriber and rebuild it as CCM 3.3(3) then perform the 3.3(5) upgrade using the same files you used during the Maintenance upgrade. Make sure to install all SR's etc so the versions match exactly.
Hope this helps!
Rob
04-16-2008 06:45 AM
Hi Michael,
Hope this helps!
Rob
04-16-2008 06:57 AM
Hi Rob,
Thanks for your information! I will install the subscriber with 3.3(3) installation disk frist and upgrade it via maintenance patch to 3.3(5) as before.
Many thanks! You solve my issue immediately!
Michael.
04-16-2008 07:31 AM
Hi Michael,
You are very welcome :) Let us know if any issues arise.
Take care,
Rob
