Cannot Retrieve Unity Connection Voicemail Messages
Hi All:
When I leave a voicemail message on a 7962 phone, there is an MWI and an Envelope icon in the upper right corner of the phone display, however when I push the Messages button, Unity asks to spell the Last and First name then press # instead of asking for a password to retrieve the message. I cannot find the missing configuration to allow message retrieval.
Any assistance would be greatly appreciatedl
thanks,
Ron
1 ACCEPTED SOLUTION
Silver
Re: Cannot Retrieve Unity Connection Voicemail Messages
Good Morning Ron,
Based on that rPSM output it's clearly going to the System Directory Handler, it looks as if there was a Direct Routing Rule taking precedence over 1. Attempt Sign in    and   2. Opening Greeting.
Post a screen shot with the list of Direct Routing Rules you have, if there is an additional rule that is first in the order even though 'not being in use' this will match all Direct calls mirroring the behaviour you have, because it works in a Top Down order. Below is an example of the issue:
-Dave
Hi Ron.
Did you associate voicemail profile to the dn?
Ensure that on voicemail profile a mask is not present
Let me know
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo:
I'm not quite sure what you mean by associate the voicemail profile to the DN. I have a voicemail profile configured with a Pilot number/CSS that was configured.
I removed the voice mailbox mask which was XXXX which was obviously non-specific (SAVED & RESET) but no change.
Ron
Sounds like Unity's routing rules are not doing what they are supposed to but answer a few of these questions.
1. Is this issue only with this single phone or all phones?
2. is this phones extension configured as a user account with mailbox on the Unity Connection side?
3. Is this an existing installation or new?
1. The issue is with all phones
2. I not sure I understand this question, however next to the User Alias is every user's phone extension under DTMF Access ID. Don't know if that's what you're looking for
3. New install
The voicemail mask will not have an effect on this behavior.
As long as the DTMF access ID matches whats on the phone your fine.
If it is with all phones that it sounds like it is a Routing rule in Connections that is not working as intended.
Here is a link to the two types and what the defaults are.  Check here to make sure that the direct routing rule attempts a sign-in as indicated in the document.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag090.html
Hi Nicholas:
Neither the Direct Routing Rules or the Forwarded Routing Rules have been modified and their status is as follows:
"There are no conditions defined for this routing rule. All calls will be matched"
Ron
Hi.
If you configure a voicmail mask in a profile, you will present to UC with calling id other than yours and you can be redirected either to another voicemail box or to a system/directory call handler.
Ron
If you press * at the prompt, are you able to login to voicemailbox with the user DN?
Check on direct routing rule what is selected on "Send to " section (should be call handler opening greeting)
Carlo
When I press the * followed by the DN extension, I receive a message: "Sorry that person is not available, record your message after the tone".
Under Direct Call Routing Rules for the Display Name "Opening Greeting", the Call Handler radio button is selected and "Opening Greeting" is selected from the drop down list.
Under Direct Call Routing Rules for the Display Name "Attempt Sign In", the Call Handler radio button is selected and "Goodby" is selected from the drop down list. When I changed it to "Opening Greeting" it had no affect.
Ron
Under
Attempt Sign In
Goodby
Here is the error.
On the Attempt Sing in, Conversation should be selected and "attempt sing in" option from drop down menu
Change it and it should work
Carlo
Carlo:
I made the following changes for DIRECT CALL ROUTING RULES - ATTEMPT SIGN IN. I reset everything on both sides and I am still getting a message that "the user is not available, please leave a message after the tone"...
Hi Ron.
So changing the attempt sing in routing rule, changed the initial message you are listening (in your first post UC was ansking you to enter the name of a person).
Is the phone's DN where you are trying to access vm, associated to a voice mail user in UC?
Can you also please share a printscreen of opening greeting routing rule, and System Call Handllers-->>Opening Greeting-->>Edit-->Greetings -->> Standard.
Carlo
Carlo:
The initial message is: "SPELL THE LAST AND FIRST NAME, THEN PRESS #". I only receive the "HELLO CISCO UNITY CONNECTION SYSTEM" message if i press the asterisk * button then I enter the DN of THAT phone then I receive the message: "SORRY BOB SMITH IS NOT AVAILABLE, RECORD YOUR MESSAGE AT THE TONE".
      CALL ROUTING - DIRECT ROUTING RULES - OPENING GREETING
  SYSTEM CALL HANDLERS - OPENING GREETING - EDIT - GREETINGS - STANDARD
Hall of Fame Super Red
Hi Ron,
On the Opening Greeting Call Handler can you please check
Edit> Caller Input and make sure that * is locked in to go to
the Sign -In conversation.
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Hi Rob:
Yes, * and # are locked...
Ron
Hi Ron.
Just to recap.
- On CUCM you have a voicemail pilot eg 1000 associated to a voicemail profile eg Default and "Voice Mail Box Mask" is      empty
- The VM profile is associated to Directory number from where you are testin.
- Make Sure , through CUCM routeplan report, that voicemail pilot number in unique on your dialplan.
- Which is the first message that you hear when you press envelope button on the phone?
- On Unity Connection are users present under Users-->Users menu?
- Have you recently istalled a new language on UC?
Let me know
Carlo
Carlo:
  • There are no dupes in the Route Plan Report
  • The users were imported from CUCM and have the DTMF Access ID associated with them
  • The initial message is: "Spell the last and first name, then press #"
  • I haven't installed any language
Ron
Hi Ron.
On System Call Handler --> Opening Greeting  Edit -->> Greetings ---> Standard Greeting.
Inf you select System Default Greeting, what can you hear as first prompt?
Let me know
Carlo
Silver
Hi Ron,
Based on>
This is for sure a Directory Handler setup with that specific search criteria, likely the System Directory Handler built-in by default.  It would be insightfull if you could also please provide screenshot of how many Directory Handlers you have, if you do have more than one check what extensions they have to cross out of the list any overlapping DN issue.
-DRP
Hi Ron,
It is very strange that you aren't hitting the Sign-in conversation
when dialing the Pilot # from a phone that doesn't have a mailbox
and then pressing Star *. It should prompt;
"please enter your ID followed by #" - which is the Sign-In conversation
We need to see why, so I would try this Tool from the excellent suite of Unity Tools to have a look
to see what info is passed to Unity Connection and what the call flow looks
like when this scenario happens and also when the Message button is pressed.
Port Status Remote Monitor for Connection (rPSM)
http://www.ciscounitytools.com/Applications/CxN/PortStatusMonitorCUC7x/PortStatusMonitorCUC7x.html
Can you please post back with this info. I'll capture a couple of examples and post them
up here in a bit
Cheers!
Rob
- The Band
Hi Ron,
First off I wanted to give my friend Carlo a big +5 for his great
work here!
Here is what the start of a call where I pressed the Message button on my phone
looks like (you see it goes directly to "Attempt SignIn;
07:48:52, New Call, CalledId=8700,  RedirectingId=,  Origin=16,  Reason=1,  CallGuid=9EDBB075B3C54C419BDC523736238400,  CallerName=Rob Huffman,  LastRedirectingId=,  LastRedirectingReason=1024,  PortDisplayName=CallManager-1-003,[Origin=Invalid],[Reason=Invalid]
07:48:52, AttemptSignIn
07:48:52, State - AttemptSignIn.cde!Dummy
07:48:52, Event is [NULL]
07:48:52, SubSignIn
07:48:52, Subscriber Sign-In
07:48:53, State - SubSignIn.cde!AnswerPhone
07:48:53, Event is [TrueEvent]
07:48:53, State - SubSignIn.cde!AuthenticateUser
07:48:53, -->SubAuthenticate
07:48:53,         State - SubAuthenticate.cde!TryCounter
07:48:53,         Event is [NULL]
07:48:53,         State - SubAuthenticate.cde!GatherID
07:48:53,         Event is [FalseEvent]
07:48:53,         State - SubAuthenticate.cde!LoadSubscriberMinimalData
07:48:53,         State - SubAuthenticate.cde!GatherPIN
07:48:53,         -->SubAuthenticatePW
07:48:53,                 State - SubAuthenticatePW.cde!ValidatePwd
07:49:00,                 Event is [TimeoutEvent]
07:49:00,                 State -
07:49:03,                 Subscriber sign-in successful. Alias - rhuffman. Extension - 7001. Caller Id - 7001.
And here is a call from external to the Opening Greeting Call Handler then pressing
Star * (after the * DTMF it goes to SubSignIn);
07:55:14, New Call, CalledId=8700,  RedirectingId=8700,  Origin=16,  Reason=8,  CallGuid=31DDD797D7E546B5ABE78BA8E1FE351E,  CallerName=Rob Huffman,  LastRedirectingId=8700,  LastRedirectingReason=8,  PortDisplayName=CallManager-1-002,[Origin=Invalid],[Reason=Invalid]
07:55:14, AttemptForward
07:55:14, State - AttemptForward.cde!Dummy
07:55:14, Event is [NULL]
07:55:14, PHTransfer
07:55:14, State - PHTransfer.cde!LoadInfo
07:55:14, Event is [TrueEvent]
07:55:14, PHGreeting
07:55:14, State - PHGreeting.cde!PlayGreeting
07:55:14, Call answered if needed
07:55:14, Playing greeting for Call Handler:  Opening Greeting
07:55:22, DTMF received [*]
07:55:22, Event is [NULL]
07:55:22, SubSignIn
07:55:22, Subscriber Sign-In
07:55:22, State - SubSignIn.cde!AnswerPhone
07:55:22, Event is [TrueEvent]
07:55:22, State - SubSignIn.cde!AuthenticateUser
07:55:22, -->SubAuthenticate
07:55:22,         State - SubAuthenticate.cde!TryCounter
07:55:22,         State - SubAuthenticate.cde!GatherID
Cheers!
Rob
- The Band
Rob:
It appears as though the call is immediately attemping to FORWARD rather than SIGN-IN. Please see below....
THX
CallData, 3, CallerId=1001, CalledId=2001, RedirectingId=2001, Origin=16, Reason=4, CallGuid=66073CA6F4874525A88406AB5F993268, CallerName=Jack Shepherd, LastRedirectingId=2001, LastRedirectingReason=4, PortDisplayName=PhoneSystem-1-001
Application, 3, 1001, AttemptForward
State, 3, 1001, State - AttemptForward.cde!Dummy
State, 3, 1001, Event is [NULL]
Application, 3, 1001, PHTransfer
State, 3, 1001, State - PHTransfer.cde!LoadInfo
State, 3, 1001, Event is [TrueEvent]
Application, 3, 1001, PHGreeting
State, 3, 1001, State - PHGreeting.cde!PlayGreeting
Display, 3, 1001, Call answered if needed
Display, 3, 1001, Playing greeting for Subscriber:  Bob Smith
Display, 3, 1001, No DTMF received
State, 3, 1001, Event is [RecordMsgEvent]
State, 3, 1001, State - PHGreeting.cde!RecordMsg
State, 3, 1001, State - PHGreeting.cde!RunEditMsg
Application, 3, 1001, -->MessageEditing
State, 3, 1001, State - MessageEditing.cde!CheckMsgMenuOpt
State, 3, 1001, Event is [EditMessageMenuEvent]
State, 3, 1001, State - MessageEditing.cde!PlayEditMenu
State, 3, 1001, Event is [HangupEvent]
State, 3, 1001, State - MessageEditing.cde!CheckMsgLength
State, 3, 1001, Event is [ManyEvent]
State, 3, 1001, State - MessageEditing.cde!SendMsg
State, 3, 1001, State - MessageEditing.cde!ConfirmSend
Application, 3, 1001, <--MessageEditing
Display, 3, 1001, Idle
CallData, 3, CallerId=1001, CalledId=2001, RedirectingId=2001, Origin=16, Reason=4, CallGuid=3693AD85502F484F9851C48A4D570A44, CallerName=Jack Shepherd, LastRedirectingId=2001, LastRedirectingReason=4, PortDisplayName=PhoneSystem-1-001
HI Ron
Can you please post the screenshot of System Call Handlers and onother of direct call routing rules?
Carlo
                         SYSTEM CALL HANDLER  - GOODBY
                         SYSTEM CALL HANDLER  - OPENING GREETING
                         SYSTEM CALL HANDLER  - OPERATOR
                         SYSTEM CALL HANDLER  - SCH_AA_MAIN
                     DIRECT CALL ROUTING - ATTEMPT SIGN IN
                     DIRECT CALL ROUTING - OPENING GREETING
                     FORWARDED CALL ROUTING - ATTEMPT FORWARD
                     FORWARDED CALL ROUTING - OPENING GREETING
Hi Ron.
Please create a new voicemail profile, use 8888 as voicemai mask and associate this new profile to a Phone's Directory Number from where you will call the voicemail pilot.
After that, please post the output of Port Status Monitor log.
Carlo
Hi Carlo:
I continue to appreciate your hard work.
I'll make the change, however my Remote Port Status Monitor is no longer working. It literally worked one time then stopped working with the error: Connection Refused by Remote Server. Others have had this issue but none of their fixes have worked. Everything is configured properly in Unity ADVANCED - CONVERSATIONS (The checkbox for Enable Remote Port Status Monitor Output is checked and the IP address of the Unity server has been added). In Cisco Unity Connection Serviceability, the Connection Database Proxy Service is STARTED. The Unity Connection server IP address has been added on the Monitor side. I even changed to a laptop to a different manufacturer. I am running Unity Connection version 7.0.1.1.
I may have to open a separate discussion for this problem.
Ron
Silver
Hello Ron,
I see you stated: "ADVANCED - CONVERSATIONS (The checkbox for Enable Remote Port Status Monitor Output is checked and the IP address of the Unity server has been added)"
By this i hope you meant that the IP of the CUC server is when the rPSM is opened and asks for the IP and not under:
IP Addresses Allowed To Connect For Port Status Monitor Output (comma-separated), which would be your workstations IP address.
PS: After you put your workstations IP it takes about 5 minutes. Also make sure your workstation does not have a firewall enabled just in case.
Please confirm.
-David
Message was edited by: David Rojas
David:
Thanks for the Port Monitor fix !!!
4339
