Cannot route calls to external sip proxy
I am new to cisco voice ,I have cisco 2921 voice gateway , which is connected to both   PRI and WAN . We need to route all calls from PRI to external SIP proxy.
I configured router for achieving this one, it did not work. Please look at the following configuration and help me ,
Building configuration...
Current configuration : 5644 bytes
! Last configuration change at 16:35:11 gmt Sun May 27 2012
! NVRAM config last updated at 16:16:01 gmt Sun May 27 2012
version 15.1
hostname Qatar_CIC
boot-start-marker
boot-end-marker
card type e1 0 1
no logging buffered
enable secret 5 $1$L4mH$WTv.bzkTh4EIjPt5LTXLe.
no aaa new-model
clock timezone gmt 3 0
network-clock-participate wic 1
network-clock-select 1 E1 0/1/0
no ipv6 cef
ip source-route
ip cef
no ip domain lookup
ip name-server 212.77.192.59
isdn switch-type primary-net5
crypto pki trustpoint TP-self-signed-3420541303
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3420541303
revocation-check none
rsakeypair TP-self-signed-3420541303
crypto pki certificate chain TP-self-signed-3420541303
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 33343230 35343133 3033301E 170D3132 30353237 30383539
33325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 34323035
34313330 3330819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100E28D 2A6699CF 9B3DDC45 E880A6EE F1FE085E FC1505A8 235742D0 D6136634
10A4C543 2EC259CC 10F9400B A39E35F1 F459C32C 10F37C23 778AFD42 4557BF5E
02F92D4D 0EC936D0 66F56A60 6ECB52BD 26D3B157 F72A8E56 AA566C8A 2D084D88
954D7A3E E8B93808 591603FD 7D742D18 5AD0ABC2 FF883BBA AF5D2E4D 5F89C60D
0C910203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 14FCE4E6 1645B7C7 C4108524 0AF0B739 CDF7DE94 78301D06
03551D0E 04160414 FCE4E616 45B7C7C4 1085240A F0B739CD F7DE9478 300D0609
2A864886 F70D0101 05050003 818100C9 47F060DC C336840C 2762F835 E073CBB2
1B1EF0D2 75E3A190 DDAAAB91 05B04A1D C0F41625 820606FE 557FE679 F2CB2D54
A85FB701 98F5BB2A 668CA514 1486DB67 637BEE47 F0B5FDA8 0F7A1652 C7E54A48
DDF0B67D C556DB7B A31E21E3 3675FC88 3B14A158 7B091816 1D16C0EB 9F67422E
73245F5C 1E2D3EF6 94F15355 8A4067
       quit
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
voice translation-rule 1
rule 1 /.*/ /300/
voice translation-profile LG
translate called 1
license udi pid CISCO2921/K9 sn FCZ1610700U
hw-module pvdm 0/0
username admin privilege 15 password 0 xxxx
redundancy
controller E1 0/1/0
framing NO-CRC4
pri-group timeslots 1-10,16
description 10ChannelPRI
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp key lgsec address 83.111.224.82
crypto isakmp keepalive 10
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto map vpn 10 ipsec-isakmp
set peer 83.111.224.82
set transform-set myset
match address 120
interface Tunnel0
ip address 192.168.16.2 255.255.255.252
ip tcp adjust-mss 1360
tunnel source 78.100.79.106
tunnel destination 83.111.224.82
crypto map vpn
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 78.100.79.111 255.255.255.248
duplex auto
speed auto
crypto map vpn
interface GigabitEthernet0/1
description $ES_LAN$
ip address 192.168.123.1 255.255.255.0
ip access-group 110 out
ip accounting output-packets
ip flow ingress
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn integrate calltype all
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 78.100.79.105
ip route 83.111.224.82 255.255.255.255 78.100.79.105
ip route 172.26.137.81 255.255.255.255 192.168.16.1
ip route 195.160.253.4 255.255.255.255 78.100.79.105
ip route 213.42.118.167 255.255.255.255 192.168.16.1 name To_Connect_SIP_PBX_in_
Dubai
ip route 213.42.118.169 255.255.255.255 192.168.16.1 name To_Connect_Magement_Se
rver_in_Dubai
ip route 213.42.118.170 255.255.255.255 192.168.16.1 name To_Connect_Magement_Se
rver_in_Dubai
access-list 110 permit tcp host 213.42.118.167 host 192.168.123.106 log
access-list 110 permit udp host 213.42.118.167 host 192.168.123.106 log
access-list 110 permit ip any any
access-list 120 permit gre host 78.100.79.106 host 83.111.224.82
control-plane
voice-port 0/1/0:15
mgcp profile default
dial-peer voice 20 voip
destination-pattern 300
session protocol sipv2
session target ipv4:213.42.118.167
session transport udp
dtmf-relay rtp-nte
no vad
dial-peer voice 10 pots
destination-pattern .T
no digit-strip
port 0/1/0:15
dial-peer voice 12 pots
translation-profile incoming LG
incoming called-number .
no digit-strip
port 0/1/0:15
forward-digits all
sip-ua
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password
login
transport input all
line vty 5 15
password
login
transport input all
scheduler allocate 20000 1000
end
400
