Cannot see caller ID on cisco 7911 phone
Hi all,
I have configured a cisco 7911 with the following configurations:
ephone-dn  40  dual-line
number 999 no-reg both
label Faith_Test 999
name Faith_Test
corlist incoming In000-002-98
huntstop channel
ephone  40
device-security-mode none
mac-address 1111.2222.3333
username "Faith_Test" password Cisco
type 7911
button  1:40
Problem is that when i am talking on the phone then there is a second incoming call, i cannot see the caller ID hence i cannot call back. is it possible to fix this error?
Everyone's tags (7)
1 ACCEPTED SOLUTION
Green
Faith,
In your ephone-dn config
name Faith_Test
huntstop channel
huntstop channel
This should mean that if this line/DN is in use then any futher calls to this number should receive busy tone
If you want to have call waiting then you need to remove the huntstop.
no huntstop channel
Now if the line/DN is in use a second caller should hear ring tone and the phone user should hear a bleep
every few seconds indicating that a new caller is waiting.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Green
Faith,
name Faith_Test
huntstop channel
huntstop channel
no huntstop channel
Alex.
Re: Cannot see caller ID on cisco 7911 phone
Hi Alex!
Thank you! This sorted the issue! The phone is working alright.
391
