Cannot start callmanager service on 6.1(1)
I have a new two node 6.11 cluster that was an upgrade from 4.13.
I have recieved my license file and applied it.
I cannot get the callmanager service to start on either node. What am I missing? Where are the log files kept on this version. I would look in the event log on my old setup.
Patrick
1 ACCEPTED SOLUTION
Re: Cannot start callmanager service on 6.1(1)
do you have the feature license????
if not get in touch with licensing so you can get it, without it you cannot start the services.
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
Thanks for the reply. I am waiting for the licensing group now.
--Patrick
93
