Cant call from SIP phone through h323 to CUCM
I'm configuring SIP 9951 phone on CME 8.6 but cant call to CUCM , at the same time with SCCP 6941 calls to CUCM there is no problem. Calls to SCCP phones on the same CME is working well too.
But when i call to CUCM from 9951 i hear in about 5 sec(silence) fast busy and call is droped.
Disconnect cause 64, invalid ie contents. What is it?
Help me please.
Thanks in advance
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
h323
  call start slow
sip
  registrar server expires max 600 min 60
voice register global
mode cme
source-address 192.168.4.192 port 5060
max-dn 5
max-pool 5
load 9951 sip9951.9-2-3-27
authenticate register
authenticate realm all
timezone 32
time-format 24
date-format D/M/Y
tftp-path flash:
file text
create profile sync 0004100543778428
voice register dn  1
number 85709
allow watch
name user1
no-reg
label user1
mwi
voice register pool  1
id mac 64D9.89C3.XXXX
type 9951
number 1 dn 1
presence call-list
dtmf-relay rtp-nte
username cisco password cisco
codec g711ulaw
no vad
camera
video
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
dial-peer voice 101 voip
destination-pattern 0[1-7]...
session target ipv4:172.16.152.253
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
1 REPLY
Can you provide the output of the following debug:
debug voip ccapi inout
when simulating the failed call, thanks
Please remember to rate useful posts, by clicking on the stars below.
242
