cant dial certain phone numbers
In the office, we have a CUCME ver 4.1 connected to a PBX Panasonic 1232 using E1 cards, we use a Router 2851 between PBX and PSTN.
Extension numbers begin with 16.. and 17.., but when I dial a phone number i.e. 1673-1478, CUCME take the first 4 digits of the number, re-routing call to the extension 1673, no to the phone number.
Dial-peers in configuration are
dial-peer voice 3 pots
description EXT PANASONIC
destination-pattern 16..
port 0/2/1:0
forward-digits all
dial-peer voice 4 pots
description PBX
destination-pattern 17..
port 0/2/1:0
forward-digits all
dial-peer voice 20 pots
corlist outgoing CoS-loc
description LOCAL
preference 1
destination-pattern [1-9].......
port 0/2/0:0
forward-digits 8
dial-peer voice 1 pots
description PSTN
  paramspace callsetup after-hours-exempt TRUE
incoming called-number .T
direct-inward-dial
port 0/2/0:0
any idea that is wrong, greetings
Everyone's tags (1)
1 ACCEPTED SOLUTION
Re: cant dial certain phone numbers
yes you have to change the dial plan but the dialplan was not good to begin with since you have overlapping between DN and outside numbers.
The only way I see is to add that extra digit to distinguish between calls inside your company and calls to outside numbers.
Try changing the destination pattern in dial-peer voice 20 pots to destination-pattern 9[1-9]....... and then dial with a prefix 9: (91673-1478).
So your dial-peer 20 would be:
description LOCAL
preference 1
port 0/2/0:0
forward-digits 8
Yes, that's a good solution. Now, I ask, if necesary add a new digit, yes is only one digit but you know, sometimes, changes in dial-plan are complicated to certain users
I have a similar idea (add one digit), the change consist in that the CME will it automatically add the digit, using "Translation-Rules", but, when I apply it, it does not work
Hall of Fame Super Gold
It cannot work. If you insert the digital automatically, router cannot understand if it was needed or not, and you have not solved anything.
The digit is needed to distinguish between local calls, and calls over the trunk.
You cannot do without it.
ok, I understand. Thanks for your help. I will follow your recommendations, thanks a lot
671
