mx
cant log in to cm 5.0.
Hi. I spun the install cd and all went well. I can console in, ssh in but not web in. I can get to the login page just fine with my browser, but it keeps saying invalid password. I use the same credentials on the console and ssh. what am I doing wrong?
thanks!
bob
1 ACCEPTED SOLUTION
Green
Re: cant log in to cm 5.0.
If you want to reset CCMAdministrator password check the following procedure:
If you have the OS Administrator password then from the CLI you can reset the
CCMAdministrator password.
Please log into the command line and type the following:
run sql update applicationuser set
password='f3f84fcd7934cd48ef4fef0d9057c21d000ffe229fbd0a247ee491927aa30f02' where
name='CCMAdministrator'
This sets the password for CCMAdministrator to ciscocisco
Then you can go into the GUI and change the password to what you would like it to be
Let me know
Green
Let me know
mx
Thats it, thank you!
119
