ezy
Cant place call for IP Phone from Outside
Hi, I have a Call Manager 6.0.1 and configured at the beginning 3 IP phones. They are registered and have the real phone numbers. Calls to outside und within the network are fine, but calls from outside are rejected (number unknown). I see on the gateway that the numbers will transfered to the Call Manager but call is not established.
Thanks in advance.
Erich
1 ACCEPTED SOLUTION
Re: Cant place call for IP Phone from Outside
Do you know how many digits your PSTN is sending you? I'd use a debug command to watch call setup. If the gateway is h.323, try "debug cch323 h225" and "debug cch323 h245".
ezy
Hi, thanks for advice and help, the problem was a translation pattern wich was misconfigured from a CME configuration before.
Thanks again
Erich
618
