Community Member
Cant record personal message or leave voicemail CUE 3.1
Greetings, im running CME 4.2 and CUE 3.1 ive configured both the CME to point to CUE using the appropriate dial-peers, specified SIP as the protocol and G711ulaw as the codec, i can access the mailbox and login but cant record a personal message using the wizard or leave a message in the mailbox, all i get is silence, config below:
dial-peer voice 9000 voip
description ** cue voicemail pilot number **
destination-pattern 9000
session protocol sipv2
session target ipv4:10.10.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 9001 voip
description ** cue auto attendant number **
destination-pattern 9001
b2bua
codec g711ulaw
no vad
Strange thing is i can record a greeting using Voiceview Express but still i am unable to leave an audible message in the mailbox.
Any suggestions would be much appreciated.
Community Member
Re: Cant record personal message or leave voicemail CUE 3.1
Did you get this resolved, I am having the same issue.
Hall of Fame Super Gold
now that is _really_ strange. Do this happens even after reload and are you using latest SW for both cue and cme ? Not to say it is know to happen with older versions ...
Community Member
Havent been able to get it resolved, think im going to downgrade to 2.3.4 i cant see where there could be an issue, ive taken the config back to square one and re-installed Unity Express using the Boot Helper image
Hardware is an NME module btw. I was running CME 4.3 then the above happened so i downgraded to 4.2 and still experiencing the same issue.
I have tried a reload, reset, shutdown and clean install.
Community Member
To give you guys an update i have raised the issue with Cisco TAC who are equally puzzled, i have faith that we will get to the bottom of it though.
Will report back when i have further news.
Community Member
Thank you once again Cisco TAC, the issue was narrowed down to the sip-ua configuration and more particularly NAT.
As my router sits behind an ASA on private IP address i had configured the ISR for nat transversal following the SIP: Connection-Oriented Media Enhancements for SIP on Cisco.com using the following commands
nat symmetric check-media-src
nat symmetric role active
The issue was identified as being the command "nat symmetric check-media-src" which checks the incoming packet for media source address. This capability allows the gateway to check the source address and update the media session with the new remote media address and port.
Once removed everything returned to normal.
Honest with you, had you mentioned you have NAT between CME and CUE, identifying the issue would have been immediate.
Remember, when exposing networking problems, always present the full scenario end-to-end, including things that appear not important to you. It will be the person listening that will tell you what is not applicable or not important.
251
