cant upgrade 6941 ip Phones from 8.5.4 to 9.0.2 or 9.0.3.a SCCP
hi,
we have an CUCM 7.1.5 with some 6941 SCCP Phones. some of them have SCCP firmware 8.5.1 or 8.5.3. I can succesfully upgrade to firmware 8.5.4.No I want upgrade them to 9.2 and at first step to 9.0.2 or 9.0.3.
But upgrade doesnt work. phone says
[14:19:....] SEPxxx Get Ip from DHCP Server...
[14:19.....] upgrade from 172.1.2.3
[14:19.....] upgrade fail (read fail)
after install the new firmware and/or change the device defaults I restarted the cisco tftp server, but it doesnt work. can anybody help?
1 ACCEPTED SOLUTION
Green
You are correct.
You need to go via 9.0.2, however it need to be the unsigned version.
See the 9.2.4 readme http://www.cisco.com/web/software/282074289/90710/cmterm-6921_6941_6961-sccp.9-2-4-3-readme.html
Can you confirm that you are using the unsigned 9.0.2 firmware
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Green
You are correct.
Alex.
The unsigned firmware was the hint. I used a 9.0.3.a unsigned. Works also. But what the hell is the reason for this? Why must used unsigned firmware only at this point? Doesnt understand Cisco.
Hall of Fame Super Red
Hi SA,
The firmware for the 6941's needs to be at 8.5(4) as a first step before going to 9.0(2) and then
you must use the "unsigned" files to move to 9.0(2)
Installation Upgrade Notes
Direct upgrades, using unsigned load files, are supported from firmware release 8.5(4) to 9.0(2). You can use the following firmware release file for these direct upgrades:
cmterm-6921_6941_6961-sccp.9-0-2-0-uns.cop.sgn
Note After  you upgrade from firmware release 8.5(4) to 9.0(2) and for subsequent  firmware releases, you can upgrade or downgrade only to signed firmware  releases.
Before You Begin
Before  you upgrade from Cisco Unified Communications Manager (Unified CM)  7.1(x) to 8.(0), you must upgrade to firmware release 9.0(2).
Installing Cisco Unified Communications Manager
Before  using the Cisco Unified IP Phone with Cisco Unified Communications  Manager, you must install the latest firmware on all Cisco Unified  Communications Manager servers in the cluster.
To download and install the Cisco Unified Communications Manager version, follow these steps:
Procedure
Step 1 Go to the following URL:
http://tools.cisco.com/support/downloads/pub/Redirect.x?mdfid=278875240
Step 2 Log in to the Tools and Resources Download Software page.
Step 3 Choose the IP Telephony folder by clicking +.
Step 4 Choose Call Control > Cisco Unified Communications Manager (CallManager).
Step 5 Choose your Cisco Unified Communications Manager version.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/6921_6941_6961/firmware/9_0_2/english/release/notes/6900_902.html#wp174986
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
1077
