Bronze
Capacity planning - H.323 gateways
I'm running through some possible changes to my network and there's something I'm not entirely clear about. What would happen if I have a setup like this:
Route List Generic-RL
Route Group H.323 gateway
Route Group Multiple MGCP T1's
Let's say the H.323 gateway only has 1 PRI. Now I have 23 calls up (the PRI is full). Now I need to send another call out the Route List. Is there anyway to have it go to the second RG instead of sending it to the one for the H.323 and just failing due to lack of capacity?
Any help would be greatly appreciated.
Jim
1 ACCEPTED SOLUTION
Green
Re: Capacity planning - H.323 gateways
That will work.
Since we will recieve a message like not available circuit this will force to hunt the call to the next RG configured.
Green
That will work.
Bronze
Huh, I did not know that. I guess I'd just been assuming it for so long I didn't think it would work. Thanks, that makes things quite a bit easier.
Jim
137
