Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
CAR and CUCM 7.x: maximum and medium calls on a VG
we have a CUCM 7.x and a VG (in H.323); the VG has some E1s.
Is it possible to get the maximum and medium calls on the VG by CAR, in a specific time range (for example, 2 months, or 1 week)?
Moreover, is it possible to get those statistics for every single E1 present on the VG?
TIA and regards.
Re: CAR and CUCM 7.x: maximum and medium calls on a VG
These are the only reports CAR has on GWs, not sure if they will fit your needs:
Configuring Gateway Device Reports
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/7_1_2/car/cardvgat.html
EDIT: Forgot to mention, since CUCM is unaware of which T1 you used as it only know the H323 GW as a whole, it will report on the H323 GW without further details of which T1 was used.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Dear javalenc,
thanks for your answer.
I hoped it was possible by CAR to get the single E1 utilization, but I understand the limitation of H.323 in this situation.
What about MRTG, instead? Do you know a configuration example for this tool?
Regards.
242
