CAR error log : Database Access Error
I am using CCM 4.2(3)sr1 and CAR 4.2. I check the error log and find errors occured every 15 minutes (scheduler runs cdr load every 15 minutes). Here is the message :
"Database Access Error. Perform the following checks 1. Database server is running. 2. Check that a DSN of the name specifed in the url field of C:/ciscowebs/art/art.ini exists. If the DSN does not exist, create a DSN with the name in c:/ciscowebs/art/art.ini which points to the server where the art database exists. Test the ART DSN to verify that there are no connection problems. 3. Check that a database of the name specified in the database field of C:/ciscowebs/art/art.ini exists on the server to which the DSN points. If these are not the same, change the database field in C:/ciscowebs/art/art.ini to the database name."
All the 3 options runs well.
Error details show 1004 error code,which is database access error in executequery with DbaDbConnect program name.
Any idea with this ?
Note: Here is the art.ini :
[artdatabase]
driver=sun.jdbc.odbc.JdbcOdbcDriver
url=jdbc:odbc:art
database=art
owner=dbo
[install]
root=C:\CiscoWebs\art
it must not be wrong, right?
Suwandy
1 REPLY
Silver
Re: CAR error log : Database Access Error
Try using DBLHelper to Reestablish a Broken Cisco CallManager Cluster SQL Subscription.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801e7ddf.shtml
113
