CAR error message
hi
when using CAR for user reports-individual bill, department bill, or top N calls,.. and do view report an error message displays 30023: data is not available for the date range selected. Data is avaiable only from Jun 11, 2007 to Jun 27,2007.
note: CCM 5.1
any ideas..
thanks
Bronze
Re: CAR error message
If you do not see any records, there are no CDR entries for that time and date range. Determine if conditions are met for CDR generation. CDR records are generated in these circumstances:
The service parameters CdrEnabled and CallDiagnosticsEnabled are set to True.
The call is established and has a talk duration greater than 0.
The call fails and has a cause code that reflects the error.
In order to set the service parameters, choose Service > Service Parameters, and make sure that the service parameters CdrEnabled and CallDiagnosticsEnabled are set to True in all of the Cisco CallManager servers, both publisher and subscriber.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00800c4d4a.html#1037699
Hall of Fame Super Red
Hi U-C,
The possible cause and resolution(s) to this issue are detailed nicely in this doc;
Data is Absent in Reports Created by the CAR Tool
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a008056bd4e.shtml
Hope this helps!
Rob
Have you enabled CDR enbled under the call manager service parameters?
have you check that CDRs are actually generated into the given path? prgram files\cisco\detail\CDR?
Please remember to rate useful posts, by clicking on the stars below.
297
