CAR fails to output if pdf selected
I'm looking at what needs to be done to output to any other format than csv. If I select output to pdf, the system just hangs.
Is there a plugin I need to install.
Currently running CM 6.1(2)
Chris
Re: CAR fails to output if pdf selected
Try restarting the CAR services and then give it a try
java
if this helps, please rate
java
www.cisco.com/go/pdi
I am having the same issue.
I have tried restarting said services, but the problem remains. No matter what report I try to run, if I select PDF as the output, IE crashes. It worked last week, nothing has changed...
253
