CAR / HTTP Status 500 - Internal Server Error
Hi All,
I getting this message when I trying to login on the CAR page. I did a procedure of restart Cisco Tom Cat and also reset the server, but I still getting the issue.
CCM version 4.2(3)sr1
CAR version CAR 4.2(1.020.000)
Please give your comments.
Andres
Silver
Re: CAR / HTTP Status 500 - Internal Server Error
If you receive the HTTP status 500 - Internal Server Error error message while you access the CAR reports, you need to restart the Cisco Tomcat Service from Start > Programs > Administrative Tools > Services in order to resolve the issue.
Still you are getting error then this is bug CSCeg52386
CAR gives error on CCM as well (with IE)
CAR is not usable because DirUser can not locate certain jar files.
Green
Hola Andres,
Do you have AD integration?
DCD?
Try to uninstall the plugin
Reboot
Install the plugin
Let us know
Hi Gogasca
Yes, I have an AD integration. What plugin are you talking about?
Andres
Gogasca
happy 2009!
Look, when I am doing re-install it is asking for put 'Please enter Private Password phrase for this cluster', is it the current windows password of the server o CCMadmin pass?
Please advise
Andres
Green
Hi Andres,
The private password is the password generated during install, you can always reset it by running Adminutility.
This will bring services down since ithey will be restarted so its recommended to do it after hours.
283
